9.11 Inside Job... MORE PROOF
Was 9.11 an inside job?
Yes
4
17%
No
6
25%
I didn't read the article, but yes it was
0
No votes
I didn't read the article, and don't need to... you're a nut
11
46%
I can't read
3
13%
Total votes: 24
DiggityBiggity wrote:One more time...
This is building 7's location.
This is building 7 two hours prior to collapse
Now... here a couple of examples of other steel structures that were on fire... that didn't even come close to collapsing
Interstate Bank Building 1988
One Meridian Plaza 1991
Caracas Venezuela 2004
Windsor Building, Madrid Spain 2005
The Dark Side of Will wrote:Pictures of burning sky scrapers are nice, but you've got to look at what was burning and where it was burning. Was there a gas line into the building? Fuel oil tanks for heat? Some refrigerants are flammable and the right (wrong) design in the air conditioning could release a lot of hot burning stuff. You just don't know enough to say one way or the other.
DiggityBiggity wrote:This is what I'm saying... Larry Silverstein admitted the building was pulled...
The Dark Side of Will wrote:You're interpreting this statement in light of your conspiratorial leanings. Was he perhaps referring to pulling the FDNY out of the building because they couldn't stop the fire? With the fire unstopable, the building collapsed on its own.
I hate repeating myself, but I guess no one listens to me beccause I'm not a ranting lunatic.
DiggityBiggity
Post by DiggityBiggity »
The Dark Side of Will wrote: Pictures of burning sky scrapers are nice, but you've got to look at what was burning and where it was burning. Was there a gas line into the building? Fuel oil tanks for heat? Some refrigerants are flammable and the right (wrong) design in the air conditioning could release a lot of hot burning stuff. You just don't know enough to say one way or the other.
zonyl wrote:I did just read two things however:
- #7 had tens of thousands of gallons of diesel fuel tanks located just below the "command center".
- McCormick Place was a steel structure that collapsed due to a smallish fire.
Hmm...
The specifics of the fires in WTC 7 and how they caused the building to collapse [“official theoryâ€
Indy
Post by Indy »
Even the Fire Deprtment suggested that the fire was NOT containable, and further efforts could result in an unnecessary loss of life. Why is it so hard to believe that they withdrew from the building and let it burn down?
DiggityBiggity
Indy wrote:Even the Fire Deprtment suggested that the fire was NOT containable, and further efforts could result in an unnecessary loss of life. Why is it so hard to believe that they withdrew from the building and let it burn down?
Letting it burn down, and collapsing as it did, are two completely different stories... Steel structures DO NOT collapse due to fire..IT DOESN'T HAPPEN!!
Your concerned leader
Diggity"It would have been gutted, not destroyed"Biggity
Indy
Post by Indy »
This steel structure did not collapse due to fire?
DiggityBiggity
Give me a before picture... tell me how many stories it was... and No.. it doesn't look like it completely collapsed... from what I see... it looks like it was the ROOF that came down..
Diggity"Give me a reference"Biggity
crzyone
JDM Power FTW
Post by crzyone »
Who cares if building #7 was blown up anyways? It was probibly always rigged with explosives to protect whatever secret material is inside. If the government doesn't admit to it, its likely they don't want other government workers to worry that the building they are working in is also rigged with explosives... that would suck.
They said the wtc came down because of the fire for a few reasons. First, the impact of the jets blew the insulation off of the support beams. And the jet fuel burns very hot and weakened the metal to the point of fatigue.
Those other buildings that are burning have their insulation intact.
The WTC was designed to take the impact of an airliner, but wasn't built to handle a fully fueled airliner and the fire it produced.
If you watch the wtc fall, it collapses right where the airliner hit it. The top floors don't come down first, the whole top of the building falls at the same time, pancaking the floors below it all the way down.
zonyl
not really
Post by zonyl »
DiggityBiggity wrote:Give me a before picture... tell me how many stories it was... and No.. it doesn't look like it completely collapsed... from what I see... it looks like it was the ROOF that came down..
McCormick Place. The paper, wood, plastic fire created temperatures great enough to twist the steel/concrete structure causing collapse of the roof, and did it all without the help of a. Plane Collision, b. Jet Fuel, c. Tremors, d. thousands of gallons of diesel fuel.
This buildings steel structure collapse under fire led to pioneering a lot of building codes. Co-incidentally this building's collapse was attributed to a lack of firefighter response (due to shortage of water) I would guess the reason we do not see too many steel structures fall because of fire because of adequate fire control.
DiggityBiggity
Great picture of the true terrorist
Diggity"Bahhh like a sheep"Biggity
DiggityBiggity
The roof of a building.. compared to a steel sky scraper.. is much much different..
What I had said was.. NO Steel Skyscraper...Much different construction
Diggity"Skyscrapers do not fall like that"Biggity
zonyl
not really
Post by zonyl »
Last time I checked, Steel melts at around 2500 deg F, regardless of being in a skyscraper or roof of a building. There was a houseware show going on at the time, so I guess it could be some sort of Women's Rights terrorist group that thermited that building as well (just kidding around with ya) :afrocool:
I wonder if anyone has looked into the amount of kinetic energy released upon collapse of the trade center buildings. That might account for the incredible heat they were seeing in the steel joints during salvage.
DiggityBiggity
What I'm saying is.. Look at the walls.. they're still standing.. it was the roof that collapsed... The roof of a structure made of steel.. and an entire steel skyscraper, are two completely different things
Diggity"Buildings do not fall like that"Biggity
crzyone
JDM Power FTW
Post by crzyone »
DiggityBiggity wrote: Great picture of the true terrorist
Heh, read what is on the wall above the prez. Thats why I thought you would love that picture :thumbleft:
Kohburn
FierHo
Post by Kohburn »
DiggityBiggity wrote:Great picture of the true terrorist
did you happen to notice that he lives in canada? real sheep alright :la:
One of them canadian sheep.
Kohburn
FierHo
Post by Kohburn »
eHoward wrote:One of them canadian sheep.
that made my day
DiggityBiggity
EFFIN AWESOME!!! I love it!
Diggity"Sorry man, I'm heated over here"Biggity
To secure peace, prepare for war.
People are all to do about windows shattering in ways that look like small detonations or squibs or whatever.
To them I pose a couple of questions...
1) How far can you fold a piece of glass at room temp?
2) Where does the air inside a building go as it collapses?
1 is relevant because the building can easily flex the inch or so necessary to shatter a window without that movement being perceptible from hundreds of feet away on film. This would make the windows appear to blow out immediately *before* the building collapses, when it is in fact the imminence of the building's collapse that is blowing out the windows.
2 is relevant because all that air is being pushed out of the building somehow. In one of the photos on one of the links, a window below the front of the collapse on one of the towers is being blown out. So what? Elevator shafts can carry airflow down the building in advance of the oncoming collapse. If an elevator door were open and a few doors in the offices on the same floor open (highly likely since people left in a panic and the power was probably shut off unexpectedly), then the pressure wave preceding the collapses could easily blow out a window ahead of the collapse.
The detonantion of 8oz of black powder can make a large window visibly flex over 100 feet away (experience). Blowing one out shouldn't take much more pressure.
Oh yeah... was that a person waving from the gaping hole, or a piece of something flapping in the wind (of which there is obviously quite a bit)?
whipped
Post by whipped »
The Dark Side of Will wrote: The detonantion of 8oz of black powder can make a large window visibly flex over 100 feet away (experience). Blowing one out shouldn't take much more pressure.
just a minor point... black powder doesn't detonate, it deflagrates. black powder requires a container, whereas something like TNT creates it's own container through its supersonic shock wave.
..just sayin :blah5:
