all Aluminum 2point8 prototype race engine???
But my pitch is 1.5. will a 12 x 1.5 tap right into the 11 x 1.5 threads? anyways, I did some testing on a 1/2 inch piece of alluminum with 11 x 1.5 threads in it, it held 95 ft lbs fine. I think there are still enough threads in all the holes to supply ample holding torque. Now I need help finding head bolts that are longer than what I have by about an inch to an inch and a half. with all the sbc heads made, there has to be a set of head bolts available. Forget studs, Its only going together once, then when it comes back apart, it will need sleeves and Ill have new holes and threads machined then.
off to find some 11 x1.5 bolts in 5 1/2 and 4 1/4 inches long. wish me luck. (I may just use the long head bolts I have in the short holes as it is.
yes but when retapping a hole larger you have to look at the minor diameter of the smaller hole - because the major diameter will be getting removed by the tap -The Dark Side of Will wrote:12 - 1.5 = 10.5
11 - 1.5 = 9.5
So the tap drill for a 12 x 1.5 hole is only 0.5 mm smaller than the major diameter of 11 x 1.5 threads.
as long as the minor diameter of the threads left in the hole is equal or less than the tap drill then it will be like a brand new tapped hole.
I'd rather shorten the threaded end as required than shim anythingp8ntman442 wrote:northsar head bolts are 11x1.5 by 173.78 mm which is 6.84 inches long.
add a few washers and Looks like im in business. Take the long head bolts and put them in the short holes and take the n* bolts and put them in the long holes. Shimming where necessary.
uhh, have you read this thread for the last few pages? Im trying to get as much thread as I can on these bolts, I dont think Ill be cutting any threads off. I will most likely have threads cut onto the other end to make studs if possible, not sure if you can do that on grade 10.9. my die cut into my stock head bolts. This may be a solution, until I know for sure, im not declaring the problem fixed. The problem with the shimmed n* bolts is the oil catch in the valve covers. But they can be removed, so not much of a problem, the bolts will clear the rockers no matter what.
Im picking up my new head gaskets and 3.4 tdc bolts today at napa. Then off to fastenal for some grade 8 washers to remove the excess length. Depending on the amount of thread on the bolts, I may remove some from the threaded end, but most likely will use 3-4 washers to make them fit. looking at .57" too long. If this dosent work, Im going 1/2" and making studs cut to length.
Well the 3.4 bolts are nice and long with plenty of threads. I had to make spacers rather than cut threads off each bolt and remove 1/16" off the diameter of the head flange. I was gonna use nice machined spacers, but what the heck, a stack of nickles with a hole drilled in them should work right MTA? I would have had a report on if it worked however the crappy head gaskets napa got me dont work because its an open deck, and the gasket dosent seal the water jacket on the outside edge.
I have a set of gaskets that are (gasket/sheet metal/gasket/sheet metal) top to bottom. Im gonna try to use them with some type of sealer on the bare metal on the bottom. Any sugestions on what seals metal head gaskets best?
[quote="The Dark Side of Will"]What did you do to this hole?
Your head bolts were 11mm originally, right?
Was this a virgin hole?
Remind me what you did, again?[/quote]
same hole that was problem b4. There were still threads at the bottom therefore I was looking for longer bolts. The threads that were left were not enough apparently because the 3.4 bolts went to the bottom and still the hole stripped out. 1/2 is bigger than 12mm I dont think retapping a 12mm into an 11mm (stripped) leaves more than short flat threads that dont hold.
My son could be born this afternoon, or anytime this week, so that leaves me with no time for the car. So I will make it another dilly dally project, and do it right. 1/2" studs are gonna cost $$$$$$$ so im gonna look into borrowing a timesert kit and get some long n* 30mm inserts. Those may work. Cant seem to find the minor dia, and od of the timesert tap though.
well, ive been on the timesert site timesert.com and looking at the engineering data, Im thinking to do this and only have once chance at saving this block, I have one good option.
12mm timeserts. A lil pricy for a college kid with baby, but a big savings in the long run. I think it will work fine holding the motor together in the future when its sleeved, decked, and boosted. It will also allow me to never have to look for 11mm bolts again. What a pain in the ass.
I was thinking about 1/2" but thats about the same price to make studs as it is to buy the timesert kit. Another related thought was that 1/2" bolts may not fit throuh the holes in a 3.4 tdc head. (I had a set of heads but cant remember) Wish I didnt sell them for 50 bucks. Im not even sure of the feasability of making this block a dohc, but why do anything to definatly rule it out, so another good reason to go with the 12mm timeserts. 12 x 1.75 timeserts require a 1/2" drill and a .552 major dia. tap. so the threads holding in the insert will be virgin and complete
no rugrat yet. still waiting.
well I actually went 7/16-14 inserts, just ordered them today, as well as the bolts. I drilled all the holes and tapped 3 of them so far (easy tapping very soft aluminum). I had to just order a bottoming tap for the kit because the holes are blind and I didnt know if the long inserts would work without fully formed threads. 1.5" holes 1.25" inserts. That only cost 21 bucks for the tap. They are not regular sized taps so I couldnt get one at a parts store.
My girlfriend is set to get induced friday morning, and I doubt the parts will be here by then, so this may take a while.
