Dyno Tuesday, Predictions?
Was a fun day, although it sucks about the results though. At least like you said there's a new base tune to go off of. I wonder though if the BS3 is what is giving all issue, Wideband not working and all. Let me know what you find out.
I have Pictures if Levi doesn't mind that I post them. They turned out pretty well.
86 Fiero SE 2M6
3.1L V6 5 Speed SOLD
06 Cobalt SS
2.0 Ecotec Supercharged 3.0 inch Pulley
15 Psi Daily Driver SOLD
2008 Hyundai Accent (HYUNDAI POWER!!!!)
06 Cobalt SS
Did it sound like it was running the same way as when we were working on it? It is funny that 2 arent working, and that is the bank you are running your WBO2 off of right? It cant be a wiring issue for the coil pack, but I dont know about the injectors, I never touched those wires, didnt even shorten them. How do the plugs look on those cylinders?
Sorry I couldnt be much help when you phoned me at work about the tach wire, I am pretty sure the ECM feeds the tach signal to the cluster on your car, since there are 2 ignition modules.
Just pulled out my old reciept book and the color is Victory Red, Color #309.
The paint was bought from Earl Scheib Paint and Body in CA.
http://www.earlscheib.com/
My car got really dirty from the truck and trailer. Its amazing how well the camera hides it. It really is a sharp car when its clean. Need to get the front bumber repainted one of these days, its rock chipped pretty bad.
I think the wide band is working. The WB is on the front bank, with the 2 dead cylinders. If both cylinders are at WOT and the other 2 are just pushing air than the air fuel ratio would do exactly what it was doing.Leafy wrote: I wonder though if the BS3 is what is giving all issue, Wideband not working and all. Let me know what you find out.
The dyno operator could not get better than 14.6:1 on the front bank, but he had the dynos WBO2 on the rear bank exhaust tip. At WOT the dyno was showing around 10-11:1. The front bank would get to 14.6 and stop.
I'm definitly leaning towards the injectors, the wiring or the computer for the problem. Not sure if those cylinders are getting spark but its likely that they are.
Ben, the car sounds like it always has, more lumpy than it should. I just chalked it up to needing a tune badly but now that the engine is "tuned" with 2 dead cylinders its much more apparent that there is a dead spot.
Tomorrow I will spend some time with the car and see if I can't figure it out. Just bought a new multimeter, my last one broke so I can test to see if the injectors are getting a signal. If there is a signal there then it must be the injectors them selves.
Here's to hoping for the easy fix. It does make sense that with the 2 cylinders being dead, the Wideband would only stop at a certain point.crzyone wrote:
Glad you like the Pictures, if you wanted to come down with the GTR when you get it running we'll do a photoshoot. I love that stuff.
![Very Happy :D](./images/smilies/biggrin.gif)
86 Fiero SE 2M6
06 Cobalt SS
06 Cobalt SS
there is a topic on the quad4 mailing list right now about bad injectors. Basically on the quad 4, the injector drivers run 2 injectors each. One bad injector can make the driver fail to run both. This could be your case. Do you know how the BS3 drives the injectors? (hardware).
Try leting it idle and disconnect one injector clip at a time. See if rpm PICKS UP. It could if the disconnected injector is the bad one, and the ecm can then fire the other.
Gotta give props to Terry on the Q4 list for this as I had never heard of it b4.
Well, good news. The dead cylinders are getting a signal to the injectors. The non working and working cylinders are all getting 6V at idle.
So this narrows it down to an injector or spark issue. I'll pull the front coil pack tomorrow, look at the spark plugs and maybe rig a way for me to check spark. These 1 piece coil pack covers are a bit of a PITA.
Are the injectors firing? Can you tell by putting your finger on one while the engine is running?
If you can't tell that way, then get a stethoscope with a probe and listen to them. You may want to pull the fuel rail off and crank the engine to see what the spray pattern from each injector looks like.
what size are stock? Might be cheaper to find new ones then have those cleaned.
Those injectors are 5 years old, haven't been run often enough to keep clean. I am thinking they are bad, and the others can't be too great IMO. Even if still good, I am sure the spray patterns aren't the best, and could be killing some hp.
