Hydrogen
why not build a floating nuclear power plat out in the ocean that sucks up "deep" water thats super cold for cooling the charge fluid and then sends it back down to the deeps.. if they don't want to run power lines to it then they can have the plant desalinate and convert water to hydrogen to be tankered to the US like natural gas is.. plus being offshore it keeps civilians away from the imediate blast zone
would be any more harmful than the oil rigs?
somehow i don't think we'd be able to affect its temperature of that much thermal mass more than the ocean floor thermal ventsThe Dark Side of Will wrote:Dumping hot water back where the water's cold can be very environmentally harmfull to all those little critters on the bottom of the ocean that we never new existed.
never said to build it over thermal vents - just that its heat input is miniscule in comparisonThe Dark Side of Will wrote:Why would you build a nuclear plant over thermal vents? Build a thermal plant over thermal vents.
Build a nuclear plant out in the middle of the cold ocean where there ain't much of anything.
BTW, I just noticed that you said "blast zone"... come on, dude.... you know better than that.
its basicly free energy via thermodynamics.. (not free monetarily)Mach10 wrote:Geothermic's the way to go. A few supaah-deep plants perched right on the many belching assholes of our planet... :salute:
figure a nuclear power plant is just using the heat released by fission to move water and turn turbines.. ..
so why not take water thats already moving and make power fro it..
concrete subs and facilities are now much more viable solution
http://www.physorg.com/news3985.html
Whatever happened to that "pebble bed" nuclear reactor idea they had a little while back? It was being touted as "meltdown proof" and the big idea that was going to turn the nuclear power industry around. Did it die, or has it just not been implemented yet? I'm guessing the later, as I don't think any new nuclear power plants have been built recently.
<Insert Sig Here>
SOLAR POWER CAN SAVE THE DAY!
yes, its actually true. it not just some wishful thinking. the sun puts out a STUPID amount of energy. just think how much juice is required to light up your city. suns does it everyday for free. and then some. puts out so much you'd die if actually exposed to the full power of the lightside. how is a giant fireball thats so many hundreds times bigger than our planet not a good source for power?
It's been covered.
The sun puts out STUPID amounts of energy.
But by the time it hits our little rock, it's too dispersed. Specifically, it's not dense enough. As will stated, we'd need a square collector running at 45% net efficiency 600-miles wide to a side to fuel our AUTOMOTIVE energy needs. Which takes up what, 20% of our overall consumption?
If you roofed your house in high-efficiency solar panels, you would not likely make enough energy to power your house for 24hrs. And that's in summer.
