all Aluminum 2point8 prototype race engine???
Edit I own page two
no I dont want to sell it, yes it is a nice sandwich, my roomate works at starbucks and gets them for free. Cook them in the oven for a few minuts and ........
anyways, I have a set of 4.9 sleves at my house in ct, will check the dimensions this weekend probably. That would be cool.
You are correct the lifter bores are fed through that tube and then they go to all the lifters.
not going dohc on this any time soon. that takes money, i dont have money.
I need recomendations on a cam lifters and rockers.
hmm those heads appear to be the small valve heads.
And you gave the dimension on the intake valve to be 38mm diameter? That equates to 1.5 inches. thats not a large valve at all.
I sawy you recheck or be more specific ont he face of the valve and its diameter.
Looking at them though they look like the small valves. I could be wrong though. Hard to tell from teh pics.
You def scored a deal though. Looks just like the stuff me and Jon got like a year ago.
They may be the smaller valves, if so Im gonna get a new set of stainless valves installed.
valve sizes are 46 mm intake and 39mm exhaust that calculates to
1.5354 exhaust and 1.811 intake
what are the dimensions of the large valves???? This was done with a pocket sized caliper set with the valves in the head, I cant get more acurate until I get the thiong home and remove the valves.
taking a closer look those are the smaller valve heads. Just swapping htem on you will prob lose hp.
Will prob need to take them to a machinist and see if they can machine the seats for the larger valves. Not sure if possible but I dont' see why not. Shouldnt' cost too much extra. Just take them over and get an opinion before you spend the money on the HO valves. Just make srue its possible first.
You will save about 50 lbs with the block and about 20 pounds with the heads so about 70ish total. Not bad.
Stock 4point9 bores are 92mm. There was discussion a while back on the Cadero Owners Forum on yahoo groups about aftermarket sleeves for that engine... I heard numbers tossed around like +4 or even +5 or +6 mm.p8ntman442 wrote:I have a set of Peice of shit sleves at my house in ct, will check the dimensions this weekend probably. That would be cool.
What's the V6/60 bore center?
The Northstar deck height is almost exactly the same as the V6/60 deck height... not sure about the 4.x architecture.
ok, so i got two different opinions, and fierobsessed is a pretty smart guy, and I talked to him for a long time at kick hill once. Soooooo, instead of argue, how the hell do I measure the compression with the engine as is, I assume I measure the volume of the compression chamber and add in a crushed gasket factor, then add the area of the piston at tdc in the bore, then do the same with the piston at bdc. Then divide the two numbers. Getting my static compression ratio? or is that dynamic. whatever how the hell do I measure the volume of the combution chamber in the first place.
OK, I got one intake valve out, let me tell you it is not easy to get an intake valve out with only an adjustable wrench and a lock pic, but my roomate and I got the spring depressed and I got it out. It deffinatly measures 46 mm at the widest point. Is that where im supposed to be measureing this thing, of the bowl opening. fyi 46 mm is 1.81 inches, which is pretty big. The good news is that the valves seem to be new, and all new valve seals are on it. yay.
do you have a stock 1.72 valve laying around to compare it to? Thtas a good way to tell right there if you are measuring right.
Trust me. I will bet one cagillion million zillion dollars that the compression ratio wont' be off the chart. Those pistons look like factory stockers. They dont' stick out above the deck height an obscene amount and also the CC of those heads is shaped like stockers. YOu will be fine
Trust me. Your compression ratio will be close to stock.
Unless you think I am wrong, and you want to sell them.
I think fieroobsessed misunderstood you because you said gen 2 heads in one of your posts and then said aluminum. he thinks you are using gen 2 heads. Not gen 1 heads like what you have there. Gen 1 heads are Fiero heads and camaro heads. Gen 2 only came on FWD cars. You have gen 1 heads but in aluminum not iron.
Is this block the same as the Bowtie block (pt # 10051141)? If not, how similar are they?
http://toddshotrods.com - wanna ride?
In the time that it would take me to one intake and exhaust port, I could usually do a complete lower and middle intake. It would be so much nicer if they made the Gen-1 heads aluminum, I'd be making a living off of porting those things!Shaun41178(2) wrote:
sculpting al heads is so easy and quick.
NO. This is NOT a bowtie block. This is a prototype aluminum 2.8 block that was not put into production. JM picked up one like it a while back very similar to this package... even had the aluminum gen 1 heads.toddshotrods wrote:Is this block the same as the Bowtie block (pt # 10051141)? If not, how similar are they?
Anyway...
Production V6/60 block has two oil galleries for the lifters, but one is bigger than the other and also feeds the cam/mains.
Bowtie block has three galleries like a small block Chevy.
TDC block has one gallery that feeds intermediate shaft, mains, and sends a passage up to the cylinder heads.
This prototype block seems to be set up like a TDC with a single gallery next to the cam that sends a passage up to a removable valley tray that has the lifter bosses.
ok, I dont have a spare valve here, Im at school, an hour and 20 min. away from anything resembling a fiero, tool, or shop rag. But I do have my handy pocket calipers and a digital camera. Now When I take this picture, the caliper reads 46mm on the inside reading and 41 on the outside reading. now since im stupid I read it wrong. looking at the thing closed the inside means using the outside of the tips. and the outside means using the insde of the tips. In other words, outside diameter inside diameter. DUH! so the valves are 41mm wide as shown in the pic.
41 millimeters = 1.61417323 inches
ho valves: 1.72 inches = 43.68800 millimeters
so there it is my valves are the small ones and I suck at reading a caliper.
