Component Weights and Dimensions
Re: Component Weights and Dimensions
I think it's a great place for it! thanks for posting, it gives me an idea of what to expect my car to weigh. I take it this is a 2.8 and TH125c?
I'll add in a data point:
85 SE
Stock V6 with turbo, Muncie 4-speed trans
Stock Hi-Tech wheels with 215/60R14 Radial T/A tires.
AC delete
Spare tire + jack delete
Rear sway bar
Floormats are installed
Me sitting in the driver's seat: 55 kg
Laptop in passenger seat: considered negligible
Fuel situation: almost full
Measurements taken at local truck scale (10 kg resolution):
Entire car on scale:
Front: 510 kg
Rear: 730 kg
Total: 1240 kg
Left tires on scale:
Front left: 270 kg
Rear left: 360 kg
Total left: 630 kg
Right tires on scale:
Front right: 240 kg
Rear right: 370 kg
Total right: 610 kg
85 SE
AC delete
Rear sway bar
Front: 510 kg
Rear: 730 kg
Total: 1240 kg
Front left: 270 kg
Rear left: 360 kg
Total left: 630 kg
Front right: 240 kg
Rear right: 370 kg
Total right: 610 kg
Yeah, 2.8/125c
- 3335280A-D859-45BD-9080-325A3510D6B6.jpeg (77.11 KiB) Viewed 1285 times
Oh wow, you're under 2800 with an automatic? Nice.Honest Don wrote: ↑Sat Jun 06, 2020 10:45 pm Is this a good thread for this?
87 notch aero-nose
A/C
Auto
Spare and jack gone, but I’ve only really pulled stuff out to put different stuff back in.
2/3 tank of gas and even the floormats are still in it.
I'm hoping to get The Mule under 2700 with a Northstar and Getrag... but have to exercise judicious component selection to get there.
What do they usually come in at?
I'm under the impression that's on the lighter side for a V6 Fiero, and I expected automatics to be on the heavier side.
Well junk... my fabbed hub carrier design is coming in at 11.89 lbs and I haven't added the toe link boss yet... better get busy with the speed holes!
Speed Holes! Add Lightness!
My hub carrier still has to hold the car up, so I can't go as far as he did.
These guys like speed holes in their uprights too: https://us.gktech.com/240sx-skyline-z32 ... kinematics
At least my assembled knuckle design for the '88's is coming in a hair under 4 lbs, although I haven't added the bolts into the model yet.
I added the toe link and an extensively relieved bracket for radial mount calipers, reworked the mount lugs for the radial caliper bracket and ended up at... 10.5 lbs. Not bad, and I haven't completely exhausted my speed hole options.
1988 Fiero lower ball joint taper: 2"/ft
1988 Fiero upper ball joint taper: 10 degrees
