bigblockfiero wrote:
These are two seperate points that I was making but I put them in the same paragraph to speed things along and because I thought you were not having trouble following this. Just a barrage of different information.
I'm pretty sure I follow what you're saying--but if there's misinformation due to wording or whatever, I won't hold it against you.
I'm no engineer, so if any of my assumptions are false, then please, feel free to educate me.
Point # 1.
Where I was going with that is to say that the squish velocity is less under say 15" of vacuum as compared to an engine at full throttle and maximum VE.
Why would that be? Lower density air has less mass, and takes proportionally less energy to accelerate; at the temperatures and pressures we're talking, the air/fuel mixture isn't what you'd call a viscous fluid. It's going to travel in relatively straight lines in direct response to the motion of the piston. It's going to move towards the lower pressure spots, with the quench area representing a high-pressure point, and the combustion chamber being the lower pressure point.
The VE of the engine, throttle position... None of these things matter because they only dictate the mass of the aircharge that's in the cylinder when the intake valve closes and the piston is moving upwards.
point # 2.
The quench groove is then what a reflective cone is to a flash light, It focuses the velocity directly tward the plug.
In point # 2 my improper use of the word THEN I now realize, kind of grouped these two together. We do this all the time in my native isle of man, Its kind of fucked up but we know what each other mean and where a little bit telepathic.
I spent 2 years in a british middle-school. I'm comfortable with both north american and english grammar styles. Don't worry about it.
I disagree with the analogy, and with the explanation; if anything, the word you're looking for is "venturi" because you're talking about accelerating a fluid. But the groove won't work as a venturi; you aren't placing a restriction that would cause the air moving through it to speed up relative to the motion of the rest of the air.
At the very, VERY best, you could make the argument that it changes the direction of the flow.
Personally, I suspect that an earlier poster is right; that you could get the same (if not better) effect by dimpling the quench area like a golfball to improve laminar flow out of the quench area.
