Another 3.4TDC Turbo up and running
Re: Another 3.4TDC Turbo up and running
How exactly are you supposed to get an air filter on the inlet? Is there at least a screen over the opening? I can't tell from the photo.
Late timing is like richening the mix, advanced timing is like leaning the mix.coinage wrote:WOT, not so much. It needs tuned horribly as under WOT, the AFR's go pig rich into the 9's. It is also breaking up but I am think it could be pulling timing from the open downpipe being loud as fuck and/or from the overly rich condition.
Turbo tuning generally pulls advance out, but pulling too much is worse, because pour-in bottles of octane booster can't fix that.
No filter but I do have a metal screen over it for some protection. The crossover is a WCF piece and probably isn't supppose to have that big of a compressor housing in that spot,
When I said it might be pulling timing, I meant the knock sensor might going nuts from the loudness of this thing, but I don't data to back it up at this time without any logs... so it was just a thought to look into when I get there.
