The others
Re: The others
The Dark Side of Will wrote: Sun Sep 26, 2021 5:47 pm I meant where your house & garage are
Oh. I’m in Omaha
Re: The others
shop looks fantastic, a little small, but still fantastic!
Re: The others
Honest Don wrote: Sun Sep 26, 2021 9:17 pm
Oh. I’m in Omaha
Oh, ok. Was going to ask how you intended to insulate/finish the interior... which is relevant to the climate based on your location.
Re: The others
ericjon262 wrote: Sun Sep 26, 2021 9:18 pm shop looks fantastic, a little small, but still fantastic!
24x36 would have been ideal, but I’m trying to keep a little bit of yard for peace in the house
Re: The others
The Dark Side of Will wrote: Sun Sep 26, 2021 9:23 pm
Oh. I’m in Omaha
Insulate as much as I can. There’s no middle ground here; it goes from one extreme to the other with maybe a dozen “nice” days in a year
Re: The others
Honest Don wrote: Sun Sep 26, 2021 9:39 pm
it was a joke, no shop is ever really big enough. it looks much bigger than my current shop, or at least deeper. it looks nice, I can't wait to start building my real shop soon, over the next few weeks, I'm going to start developing plans.
Re: The others
Honest Don wrote: Sun Sep 26, 2021 9:43 pm
Oh. I’m in Omaha
Ok, maybe it’s not *that* bad usually, but it seems like it this year. It’ll be finished out in drywall and I’m doing overhead radiant tube heat. I also have a line on a mini-split to cool things down in the summer.
Re: The others
Oh. I’m in Omaha
Looks like 2x6 wall studs?
You can alternate 2x4 studs on a 2x6 plate to result in better wall insulation. Too late now, though.
https://basc.pnnl.gov/images/2x4-wall-s ... ion-around
Re: The others
Interesting concept, but yeah, my walls are 2x6. The 12' ceiling and 2nd floor required it.
Re: The others
Ehhh... single pitch roof with a deck on top would have smoothed that right over...
Re: The others
The Dark Side of Will wrote: Fri Nov 12, 2021 9:15 pm
That type of layout did come up during early discussion.
Paint!
They’ll rent one of these to just any random asshole! It goes fast. I should have only done a 2hr rental instead of the whole day.
Re: The others
So what if it gets dark early?
And some fancy to clear up overhead space.
Re: The others
what do you think of the new GDO? I've been eyeing up that style, I like the idea of maximizing the available room, especially because I don't have high ceilings in the garage.
Re: The others
ericjon262 wrote: Mon Nov 29, 2021 9:38 pm what do you think of the new GDO? I've been eyeing up that style, I like the idea of maximizing the available room, especially because I don't have high ceilings in the garage.
Seems to work ok. I don’t have the internet whatnot set up yet, but it opens and shuts an 18x8 without issue. Has an electronic deadbolt that I kinda like as well.
Re: The others
“Upstairs.” The ceiling is about 8’ in the middle.
The stapler hasn’t been the same since the fall…
Re: The others
The heater showed up this week. Too cold to really do anything with it just yet.
Looks sort of like this when installed. A number of shops I go into have this style and they’re happy with the performance and economy.
Re: The others
Looks like you don't have plumbing in the garage, so you won't have to keep the heat on 24/7 to keep things from freezing.
I know that attics are often left open with air circulating and the roof deck assuming ambient temperature.
How does it work with insulation covering the underside of the roof?
Re: The others
pmbrunelle wrote: Sat Jan 08, 2022 12:18 am Looks like you don't have plumbing in the garage, so you won't have to keep the heat on 24/7 to keep things from freezing.
No plumbing, but I'll keep it at a "sweater weather" minimum once done.
There are baffles sandwiched between the roof and the insulation to keep the underside vented.
https://youtu.be/KGLOsL_GuNo
Re: The others
Slow going, but the heater should be ready just in time for spring.
