Performance intake/exhaust options
Automatics suck across the board and hypoid bevel gearsets (RWD differential) suck up power.
I think that loss % through a 282 goes down as power goes up. I wouldn't think it would use more than 10% at 300 HP.
nfswift
Post by nfswift »
Ok, I fold!
The iron heads will get shelved.
I saw the comparison of $900 race ported irons flowing the same CFM as stock Aluminums... I guess I'll just have to convert the block over.
The comp ratio is hellishly un-turbo friendly though.
Metallic Silver 1986 SE
Just buy a whole Gen III engine. You can pick them up for less than $500.
nfswift
Post by nfswift »
The Dark Side of Will wrote:Just buy a whole Gen III engine. You can pick them up for less than $500.
Not where I live, not at all.
And plus, the 3.4 short block is already in the shop, it's going to be how it's going to be.
Then buy 3.4 aluminum head pistons, if you are going to get the aluminum heads then.
Yeah, just use the 3400 pistons. I like the Gen III blocks because they accept roller cams.
nfswift
Post by nfswift »
Well what cam options would be good and strong in the 3400?
Can I use both roller and flat-taps? Roller cams are great and all, but very pricey for an application where I don't need ABSOLUTE performance, just good sound performance.
There are several cam options for the 3400. However a new cam is out of your budget.
You can't run a roller cam in a 3.4 block though. Only the 3100/3400 blocks have provisions for the roller cams.
If you are using the 3.4 block, then use a crane 272 cam and matching springs lifters, pushrods, retainers, and lifters. It will have good "sound"
nfswift
Post by nfswift »
Shaun41178(2) wrote:There are several cam options for the 3400. However a new cam is out of your budget.
I'm not refering to cam lope, I mean a stout powerband, strong acceleration, etc. The 272 is pretty weak on the vacuum though and should, like you say, produce a neat sound.
Will the 272 honestly get me decent results with a 3400 or am I shooting myself in the foot here?
272 is about as big as you can go off the shelf. It will work fine with a 3400. Others have used it. It idles fine. Decent vacuum.
Do you want to go smaller then a 272?
nfswift
Post by nfswift »
I doubt I'd go smaller, seeing as I would LIKE to make 200WHP, but would be satisfied achieving 200 crank and slowly working my way up to 1HP/C.I.
So I should still be budgeting for some decent flat-tappet parts.
Would any of ARI's in-house cams rival the 272 for HP/dollar?
Their "phase 3 cam" is spec'd very, very closely to the 272 but there is a huge difference in price... "you get what you pay for" though.
A tough decision.
BigRedDeckSpoiler
Post by BigRedDeckSpoiler »
A quick Google search came up with this site
http://www.fullthrottlev6.com/forums/sh ... hp?t=33452
It's a list of 60* v6 cams.
Stock 3.4
195/201 .390"/.410" 109°
Comp Cams
High Energy 240H (16-115-4)
192/200 .390"/.390" 108°
High Energy 252H (16-232-4)
206/206 .425"/.425" 110°
High Energy 260H (16-233-4)
212/212 .440"/.440" 110°
Crane Cams
PowerMax 2020 (254112)
198/204 .401"/.423" 104°
PowerMax 2030 (254122)
204/214 .423"/.423" 109°
H-260-2 (253901)
204/216 .427"/.454" 112°
H-272-2 (253941)
216/228 .454"/.480" 112°
Crower Cams
Mileage Compu-Pro Lv1 (03040)
182/192 .386"/.387" 114°
Mileage Beast Lv2 (03002)
194/202 .390"/.410" 109°
Baja Beast Lv3 (03015)
204/214 .422"/.444" 112°
Ultra Compu-Pro Lv4 (03043)
212/218 .435"/.449" 112°
Hi-Draulic Hauler Lv4 (03050)
226/234 .470"/.492" 108°
Edelbrock
Performer-Plus (3790)
204/214 .420"/.442" 112°
GM Performance Parts
12363220
204/216 .427"/.454" 108°
12364059
Lunati
High Efficiency (06312)
195/205 .405"/.427" 112°
Melling
Select Performance (MTC-5)
204/214 .420"/.443" 112°
Schneider
252-56H (02371)
194/204 .390"/.410" 110°
256H (02370)
204/204 .420"/.420" 110°
256-2H (02372)
204/214 .420"/.440" 112°
131H (02375)
208/208 .420"/.420" 110°
135H (02373)
218/218 .460"/.460" 110°
270-84H (02374)
214/224 .440"/.460" 112°
Solid or Solid Roller cams also available
60° 3100/3400/3500 FWD V6 Camshafts
(Roller Hydraulic Lifter, 1.6 Rocker)
Stock 3x00
197/197 .436"/.436" 112°
_________________________________
Check out the Crower Hydraulic Hauler.
It's got a bit longer duration than the 272, and seems to have the highest lift of any off-the-shelf hydraulic.
When I started hearing about people wiping out 272s in a few thousand miles (apparently not as widespread as I first thought) I was tempted to go with that one.
Go to http://www.crower.com/pdf/2-52.pdf
Scroll to page 18 or thereabouts.
They also recommend a spring kit that actually seems to be pretty straightforward. (Stock spring diameter, etc.) I'm not sure what you'd have to do to make it work with the aluminum heads, however.
To anyone who cares...
It's interesting that the stock iron head 3.4 has a "staggered" cam profile (exhaust has higher lift than intake), while the 3x00 seems to have a "square" profile.
Do the aluminum heads flow that much better in the exhaust ports, compared to the intakes?
BRDS
"staggered" = dual pattern (different lobes for exhaust and intake)
"square" = single pattern (same lobe profile for exhaust and intake)
BigRedDeckSpoiler
What I'm wondering is, since the 3x00 ships with the square profile, would it be beneficial to keep that square profile if the aluminum heads were going to be used, instead of going with the staggered profile such as the 272 or the Crower.
Just something to think about, before spending a bunch of money. I don't know anything about the aluminum heads, other than they're "better".
BRDS
nfswift
Post by nfswift »
Yea another alternative to the 272 was the Crane PowerMax F-228/3067-2-12 which looks like
duration@.050"-advertised duration-lift-lobe center
IN/EX|IN/EX|IN/EX|IN/EX
228/238| 290/300| .460/.480| 112/112
However, hiking the profile that much will probably only start to make the engine more unstreetable.
Matching the cam to the rest of the valvetrain is a good idea when considering lifespan, I guess I should be looking for the proper MATCH for the cam rather than the accepted benchmarks, IE LS6 valve springs etc.
