Sinister Fiero wrote:
As far as the equal length primary tubes are concerned, I think too many people make this into something more than it really is. Equal length headers are not going to add 50hp vs. non-equal length units. As long as you make sure the size primary tubing you use is large enough for the application and there are no bottlenecks, then non-equal length units will work fine. Would equal length primary tubes be better? Sure; if you have the room to use them and the funds to cover the extra cost. But I don't think they are absolutely necessary to make good power. I have never seen any dyno comparo tests that showed equal length headers made even 10% more power than non-equal length headers of the same size and overall length.
-ryan
I agree with most of this. The cost and fitment are a priority over performance. The header won't do any good if it doesn't fit. There's no doubt about that.
But let's look at my case, where the header is custom designed, one-off. Fitment is an issue, however by design I was able to easily fit, in proper dimensions, an equal length header on both sides. I think that I could design, build, and install a dimensionally appropriate equal length header on most any common Fiero engine swap, including the N*/SBC/LSX. So while I haven't done this, I'm pretty sure I could, and if anyone's willing to pay the money it'd cost, I'd do it. But let's not go into that argument.
Then cost. Again, in my situation, it isn't really an issue, as the only higher price is the price of piping, which was negligibly more expensive, maybe $40-$50 at most. However if I were to be designing the header for a business or a customer, the price would be
much higher, as equal length primaries add an enormous amount of time and work to the design and building phase.
As for the power, that's where I kind of disagree. The shorty style headers on a LS1 F-body have shown to not gain
any power over the stock manifolds. Whereas the long tube, equal length headers from all brands have shown increases of 20-25rwhp. This is a big gain, definitely enough to feel. As for the mid length, non-equal headers for the LS1, I couldn't find any dyno numbers, because no one buys them :scratch:
To summarize, I can see why companies don't offer LTs for a 3800 Fiero. The market isn't there. But for a one-off, custom application where time doesn't equal money, there's no reason not to, and plenty of reason to build them LT equal length. And for a market as big as the LS1 F-body, the LTs are the only headers that sell. And sure you can always make decent numbers on a non equal length header, I mean the new Z06 makes 505hp on cast manifolds. But there's more power to be had with LTs. I think there would be quite a market for a LT equal length header for the 3800 W-body, but the price of production would be really high, especially when you can put on a smaller pulley and pray KR doesn't blow a hole in a piston for $100.
