Jinxmutt wrote:The "still" doesn't look water tight. Not really sure how well ice water will stay in there. If it leaks, you can forget about using it on the track
Well, since I made myself a new TV cable and got the shift kit installed, I decided to do a little more testing tonight and actually ventured outside of the neighborhood. I'm sure my neighbors thank me HA!
I was able to confirm that my TCC lockup circuit is wired properly, although I need to get the engagement dialed in a little better. Now that I know this, I can tie up the rest of my wiring, mount the magnadoodle properly, and put the console back together
I ran into a couple more 20yr old car issues though:
First is that my distributor O-ring decided to start leaking on me. Hopefully its easier to get than a TV cable
Second is that this thing is fucking scary at highway speeds. Upon further inspection, I'm needing some front wheel bearings....BAD
I'm getting called out of town again, but hopefully I can get these knocked out over the weekend
For the reference, it's the same O-ring that the small block Chevy used, I just got one for that. Auto Parts stores are good at charging $20 for it if it's for a V6, and 50 cents if it's for a SBC.
You're already megasquirted so wiring shouldn't be hard. Do a 3400, 3100 would be the same work for less power, unless you wanted the powerband slightly higher for your turbo but its not like even the L44 is a high rpm screamer. You may have to fab a front mount and come up with a dog bone bracket, but maybe some of that stuff can transfer from the L44.
A non-VVT 3500 has the same basic complexity of install as a 3100 or 3400. I don't recall if the non-VVT 3500's used throttle by wire or cable throttles, but I think that would be the only thing that would be different. The throttle by wire engines can be converted to cable throttle easily enough.
You *might* try ed morad, at the risk of getting overcharged, but he will have a complete motor he knows the story on and the harness. However you will never talk to him, a guy named Eric will help you.
