all Aluminum 2point8 prototype race engine???
Timeserts work in a similar way like a helicoil would.
Helicoils dont' pull out do they?
Sort of the same principle.
If I were you, I would get the timeserts, and then buy ARP head studs.
Using bolts the first time on the block was probably not a good idea. When using aluminum parts like blocks or heads or intakes, its always best to use studs but of course that is not always the most economical. Studs keep the threads from getting torn up.
p8ntman442 wrote:$$$$$OUCH$$$$$ did I mention the new baby on the way?
IF the old threads pulled out what will keep thetime sert from pulling out?
What condition were the old threads in? Heat cycled... corroded... fatigued... stress fractured from repeated R&Ring of cylinder heads...
installing an insert cuts virgin threads, which are then used only once when the insert is installed.
Also, the timesert has a larger OD than the bolt, which means that it pulls on a larger chunk of the block than the bolt did and is thus stronger.
Different things hold helicoils and times serts in place. Unscrewing a bolt from a helicoil tries to expand the helicoil against the inside of the hole, holding it in place. Time serts hold by being cold formed in the hole during installation.Shaun41178(2) wrote:Timeserts work in a similar way like a helicoil would.
Well I removed one head yeasterday and not much damage at all. The threads on the head bolt that was really bad actually threaded off the bolt when it was out, so maybee it was a HELICOIL, i dont think normal threads would do that. The kit for the timeserts for M11 X 1.5 is 125 bucks plus 13 more inserts at whatever they cost. 5 come with the kit and I figure 2 extras just in case. I Ran a die over the old bolts and that size seems to be correct. Anyone think otherwise?
Ok ive been digging and obviously 11mm bolts arnt made, not here in the us atleast. So opinions are welcome.
what I think I should do is buy arp studs for my block insert them with loctite into the existing threads. (the old head bolts only went .8" into the 2.3" hole leaving a lil over an inch of threads). Then Install the heads over the studs and torque to 85 ft lbs (fiero 2.8 specs are higher than I need for this motor, smaller valves make less power) my manual for older 2.8's show anywhere from 75-95 depending on application. If they pull out, I still ahve it out of the car and can get the time sert kit and use the northstar inserts (longer) to fix the holes.
cost: arp studs $82 plus $150 time sert kit with n* inserts.
problem: arp studs arnt long enough or threaded far enough.
I could also get the timesert kit and use the n* inserts with the long head bolts in the short holes and longer possibly n* bolts in the longer holes.
anyone ***cough*** will ***cough*** know the length of n* head bolts? I need about 6" (no jokes guys)
Huh I have ARP head studs in my al block(head rack) for a mock up and I screwed them in and was still able to get the heads on there with the threads still sticking out to put the nut on.
Are you saying your head bolt threads are deeper then what a stock block is?
Do you have the ARP head stud kit yet?
I was going by the picture of the arp studs on summit. My thread holes are 2.5" deep, so Id like to get atleast 2" of threads in there. If I get the time sert kit with 12 mm sleeves, I could go with grade 8 12 mm bolts that I chop the heads off to make my own studs. That way im pulling straight up not twisting on the time serts. 12mm is pretty big but will fit in the holes in my heads, except at the very top where there is some material left that wasnt removed after the casting.
going up to 12mm will change your torque specs - but will make it easier to get replacement boltsp8ntman442 wrote:I was going by the picture of the arp studs on summit. My thread holes are 2.5" deep, so Id like to get atleast 2" of threads in there. If I get the time sert kit with 12 mm sleeves, I could go with grade 8 12 mm bolts that I chop the heads off to make my own studs. That way im pulling straight up not twisting on the time serts. 12mm is pretty big but will fit in the holes in my heads, except at the very top where there is some material left that wasnt removed after the casting.
Anyone keep up with USCC?p8ntman442 wrote:I was going by the picture of the arp studs on summit. My thread holes are 2.5" deep, so Id like to get atleast 2" of threads in there. If I get the time sert kit with 12 mm sleeves, I could go with grade 8 12 mm bolts that I chop the heads off to make my own studs. That way im pulling straight up not twisting on the time serts. 12mm is pretty big but will fit in the holes in my heads, except at the very top where there is some material left that wasnt removed after the casting.
Remember that MkII MR2 that had a 3SGTE built to turn 10,000 RPM (built by Trueleo, the same shop that makes the high flow 2point8 intakes)? The SCC writers thought it was the most amazing thing in the world that the guy drilled the block and head out for bigger head bolts so that he could run crazy boost and insane RPM... Here you are doing that very same thing just to make it easier to get bolts...
Chevy guys go to bigger head bolts on occasion as well. Been doing it for years, even.
As a tidbit of info, upgrading to 1/2" head bolts was part of the standard Super Duty prep.The Dark Side of Will wrote:
p8ntman442, you might want to think about having ARP just make you a set of bolts. One thing that I would be concerned about would be that modifying the bolts could affect the heat treat and possibly weaken the part. Speculation on my part, but maybe something to consider? It probably wouldn't be catastrophic failure if a stud failed, but that's never a fun thing...
Nate
Ok, I got some refference books here at work and Im gonna do some research into the diameter of threads and the holes they are made in, so I can figure out what size bolts will go in good, im not sure 12 mm threads in a hole already tapped for 11 will hold up at all. Testing on a chunk of aluminum will be done first. I doubt cutting the head off a grade 10.9 12mm bolt will drop its tensile strength more than 10,000 psi
besides im running less than stock 2.8 hp for now so im not too worried about sending the heads into the stratosphere.
![Wink ;-)](./images/smilies/wink.gif)
metric thread pitch is a handy thing - if an 11 and a 12 have the same thread pitch you can run a tap right into the 11 and open it upp8ntman442 wrote:Ok, I got some refference books here at work and Im gonna do some research into the diameter of threads and the holes they are made in, so I can figure out what size bolts will go in good, im not sure 12 mm threads in a hole already tapped for 11 will hold up at all. Testing on a chunk of aluminum will be done first. I doubt cutting the head off a grade 10.9 12mm bolt will drop its tensile strength more than 10,000 psibesides im running less than stock Boat Anchor hp for now so im not too worried about sending the heads into the stratosphere.
yeah and the drill for an 11 is less meaning you can retap a hole larger asuming it hasn't stripped out beyond the minor diameter of the 12mm boltThe Dark Side of Will wrote:Tap drill = nominal diameter - pitch
12 x 1.75... tap drill = 10.25
the tap for the 12x1.75 will thread right into the existing 11x1.75 threads and cut them deeper
