Man I want a plane
Man I want a plane
I've always wanted to fly - more freedom to roam around, like a rollercoaster without the tracks, 300hp can take you to over 300mph, pull up to 9 g's (if only you could stay conscious through that), and other than that big thing we call the ground there isn't much to accidentally run into and there are always parachutes. I also have a facination with any craft that can maneuver like a helicopter.
anyone else fly or want to fly / build a plane some day?
Re: Man I want a plane
My parents had a 182 that I would fly VFR on. Its quite fun, although we have had quite a few scary moments. You can accidentally run into some pretty bad storms and microbursts. We ended up getting a stormscope after a microburst just about took us into the ground.Kohburn wrote:I've always wanted to fly - more freedom to roam around, like a rollercoaster without the tracks, 300hp can take you to over 300mph, pull up to 9 g's (if only you could stay conscious through that), and other than that big thing we call the ground there isn't much to accidentally run into and there are always parachutes. I also have a facination with any craft that can maneuver like a helicopter.
A friend of ours has a couple of restored P51 Mustangs. Really cool to see those fly around the airport. Lets just say this man has a lot of time / cash.
My father in law has a 206 that he lets me fly when I go and visit. It is pretty fun, he makes me take off and fly. Only thing I don't do is touch down, that part is alittle tricky.
I have an opertunity to work for a company that would pay for half my helicopter licence and I would be a remote oil field operator. Its like a 2 week in 2 week out job but I get to fly instead of drive. I may go for it but it is a cut in pay.
I always figured I will buy an ultralight someday, they can be found for around $15k, cheap.
military background?V8Mikie wrote:I pulled 8.6 before I got tunnel vision, then negative 4 something and puked.
yeah - anything open feels a lot faster than it necessarily is - plus you can see everything around youFierochic88 wrote:My dad has an ultralight. It certainly doesn't pull "g's" and maxes out at about 45 mph but there's something about that "open" plane that's pretty damn cool. I enjoyed going for a ride in it. He has a "trike" which is basically like a hanglider with 2 seats under it and a motor on the back!
I've been doing research into WIG's (wing-in-ground effect) since they can be liscenced as a boat and thus not need a pilots liscence - they skim a few feet above the water - land and take off from water o or can putz around like a boat. might be a good starting point since I live 1/2 mile form the chesepeake bay , and only a few miles from the patuxent and patomic rivers.
http://cgi.ebay.com/ebaymotors/ws/eBayI ... gory=63677
Your Fuehrer
Diggity"I want a plane too"Biggity
Your Fuehrer
Did you see the Mythbuster Episode on the backpack helicopter? I really though it was going to work. Im thinking they needed some bigger props as the hovercraft ones they had are for creating air volume not pressure.The Dark Side of Will wrote:Navy NFO training.
500' AGL, 300-360 kts.
Ejection seats.
I'm through flying like that.
I have designs in my head for backpack helicopter and practical jet pack, as well as VTOL personal jet the size of a motorcycle with manual thrust vectoring.
yeah they need high thrustzonyl wrote:Did you see the Mythbuster Episode on the backpack helicopter? I really though it was going to work. Im thinking they needed some bigger props as the hovercraft ones they had are for creating air volume not pressure.The Dark Side of Will wrote:Navy NFO training.
Ejection seats.
and will I've got sketches and math scribbligns in several pads of paper dating back to middle school of various VTOL designs - even started making a scale model some time ago but then life caught up to me and I ran out of spare time..
hoping to be able to get back into tinkering after i get this fiero back together and running this fall - love the fiero but it takes up so much time
I have had similar ambitions and been following the skycar guy since I was in high school. He has been trying to build a VTOL for about 20 years using gas engines. Still has yet to produce a vehicle that is reliable.Kohburn wrote:yeah they need high thrustzonyl wrote:Did you see the Mythbuster Episode on the backpack helicopter? I really though it was going to work. Im thinking they needed some bigger props as the hovercraft ones they had are for creating air volume not pressure.The Dark Side of Will wrote:Navy NFO training.
Ejection seats.
http://www.moller.com/skycar/
www.airscooter.com
Piston powered helicopters have the highest mishap rate of any kind of aircraft... Turbines and nothing but...
isn't the thing in the link piston powered?The Dark Side of Will wrote:www.airscooter.com
have you seen the version of that craft that uses a pulse jet engine on the tip of each blade?
- 9 G's - would require one hell of and acft (1/2 million dollars or more....more likely 1 million $+) - Also, would require a G suit.Kohburn wrote:I've always wanted to fly - more freedom to roam around, like a rollercoaster without the tracks, 300hp can take you to over 300mph, pull up to 9 g's (if only you could stay conscious through that), and other than that big thing we call the ground there isn't much to accidentally run into and there are always parachutes. I also have a facination with any craft that can maneuver like a helicopter.
- 300HP, maybe with a Glassair or higher. If you're talking 300 HP you're looking at around 1/2 mill as well. Older 182's run about 50k and up with 225HP with a constant speed prop and they're no barn burner - more of a work horse. Operating costs are huge if you fly a lot.
- there isn't much to accidentally run into...... you'd think, but read FAA reports, it's amazing what stupid people do.
I'm not sure if you have a particular acft in mind, but the figures you have listed are pretty extreme for teh average poorman. A Glassair or Lanceair is what you are close to there, which comes in a kit and would cost 100k with a lot of hours of work and no avionics. If you could settle with 150HP and 120knots, 3 G's then you could buy an old 172 for 35k, somewhat cheap operating costs.
If you want the shit scared out of you then try skydiving. I have about 400 jumps and it's still fun. I am a licensed pilot but can't afford to fly now, but I will get back into it soon.
Considered to be the best all around homebuilt is the RV series. I actually bought an RV-4 tail kit 15 years ago, but never started it and sold it.Kohburn wrote:I've got a thing for experimental aircraft :thumbleft:
http://www.vansaircraft.com/
RV-8 quickbuild is 26k, which requires 800 hours if you know acft manufacturing processes/blueprints/etc... Then 25k for a new motor, 2k for a prop, unless you go constant speed then it's 5k, 3k - ????? for avionics..... get the picture? And that's a budget acft kit. It does 200 + MPH tho, very reliable and sturdy. Figure 60-70k if you go with new stuff and do it right.
Get the idea? This is such a fucking expensive sport that the poor man is out.
I agree tho, I am a homebuilder too. I will but an old 182 jump plane when I get my new career,but I want to build an 8.
