Racing Rotors
Racing Rotors
A friend from work used to work in Ontario at a carbon fiber business. They made specialty CF parts for race cars like splitters, wings and other structural parts.
He brought one of the rotors they used to make for the Lola racing cars they built parts for. Here are some pics.
The rotor has a graphite core with pressed carbon fiber as the friction surface. These are super light and huge.
Wear indicators. This rotor was only on for a short test run so there is plenty of life left.
I asked him if he could get more of them so I can have one (hopefully 4 of them). :afrocool:
I wonder why they dont do 380si aluminum rotors like the cyl walls in my proto block. The aluminum would disperse the heat so well, they would last forever, and they would weigh nothing. The down side would be that you would have to run iron pads, which would probably make a lot of noise.
Probably warp the shit out of them. Also aluminum starts getting sticky really quick. On top of that, I thiiink brake rotor temperature can exceed the actual melting point of aluminum if you're getting on them enough?p8ntman442 wrote:I wonder why they dont do 380si aluminum rotors like the cyl walls in my proto block. The aluminum would disperse the heat so well, they would last forever, and they would weigh nothing. The down side would be that you would have to run iron pads, which would probably make a lot of noise.
No the aluminum is an alloy containing silicone. Acid etching eats the aluminum away to improve hardness.whipped wrote:http://www.freepatentsonline.com/5407035.html
Cylinder bores have a water cooling jacket and are lubricated by oil. The aluminum only survives because of measures taken to reduce friction.p8ntman442 wrote:yet they work for cylinder bores? I call bullshit.
Bake rotors have neither cooling jackets nor lubication. Their operation depends on large amounts of friction.
Aluminum is a lousy brake rotor material.
Wilwood does make aluminum rotors for specific racing applications:
http://www.wilwood.com/Products/002-Rot ... /index.asp
This is very cool:
http://www.imp.mtu.edu/information/brake_rotor.htm
Aluminum rotor with bonded steel friction surfaces. They claim the cost for making them is comparable to standard rotors.... but I certainly have seen them in production, so I don't know what come of it.
It always seems like there's at least 1 or 2 Rolex DP cars that have their rotors blow up during an endurance race...whipped wrote:I bet there's nothing like having to worry if your brakes are going to shatter on a hard stop.
IIRC, one of the DP cars at this years 24 hours of Daytona had a rotor blow and almost take the driver out.
