can you repair power mirror
BC2002SS
Post by BC2002SS »
the driver side power mirror seems like the mirror and what it is mounted to are about to fall out of the housing. is there a way to tighten it up or do I have to replace the assembly?
2002 Camaro SS
1986 Fiero GT 3800SC 4T65E-HD
12" Corvette brakes
1.81 60' 13.004 @102
The mirror is attached to the power base via two plastic ball joints, perhaps they're disintegrating. = mirror falls off base.
The base is attached to the housing via three Phillips head screws. I guess its possible these screws could have backed out some. However I've always had trouble backing them out with a screwdriver on just about ever Fiero I've come across, they're normally rusted down.
One of the two.
I bet it is more than likely a problem in the switch (nvm).
So yah I don't read posts....What he said.
BC2002SS
Post by BC2002SS »
it's not the switch. it is inside the housing that is very lose.
2002 Camaro SS
12" Corvette brakes
I don't even think I read what you typed, at all. I some how got from the mirror being loose, to the side-to-side movements not working at all. Sorry...
BC2002SS
Re: can you repair power mirror
Post by BC2002SS »
I need the triangle bracket that holds the power mirror motor to the mirror housing.
The bolt hole ears broke off of the one I have. does anyone have one?
Thanks!
2002 Camaro SS
12" Corvette brakes
BC2002SS
Post by BC2002SS »
Can't find the part I need anywhere. This is what I did to get by till I get a good piece.
I made some tabs to hold the bracket in place.
and a closeup
2002 Camaro SS
12" Corvette brakes
I wish I could help you out, I just don't have the piece. :\
Car looks dirty. You should get that nephew of yours to clean it. 8)
BC2002SS
Post by BC2002SS »
I hate all the pollen in the air. this looks like it will be fine, glued the mirror back on so we will see how long it lasts. it was free so what the hell.
2002 Camaro SS
12" Corvette brakes
p8ntman442
cant get enough of this site!
Post by p8ntman442 »
Bob at kick hill dosent have one???
BC2002SS
Post by BC2002SS »
maybe some place in the barn but we couldn't find one
2002 Camaro SS
12" Corvette brakes
