Custom Pushrod Intake made by Will.
The ideas behind building a dual plenum manifold are:
* Eliminate or mitigate the 135 degree turn that the runners make as they bend back under the upper manifold and go toward their destination ports on the opposite side of the engine.
* Eliminate the intake throat constriction just behind the throttle body in the stock manifold.
* Shorten intake runners significantly, biasing the VE curve toward high RPM.
* Increase plenum volume significantly, also biasing the VE curve toward high RPM.
Final result.
sorry for the crappy pic but it was from my phone.
The tb on it now is a DM ported to 57mm but I plan to put on a 62mm tb shortly. I have started to tune on 15-16 lbs of boost, and I am now running 30 lb injectors. I blew a vacuum line off the other night on the higher boost as I didn't have that particular line zip tied. It was fine on 10 lbs.
Here is a video of me swapping from the stock to the custom intake
http://videos.streetfire.net/video/inta ... 203986.htm
Final result.
Last edited by Shaun41178(2) on Fri Dec 19, 2008 11:18 pm, edited 1 time in total.
I don't care about a video about how it's swapped. A video on the dyno or the track would be much better :thumbleft:
Seriously though, I wonder what kind of power differences the intake and TB have given you.
Easy. It's a couple of boxes welded to the stock lower (But with the stock lower flanges cut off), then some pipes welded to the Y. And it's steel. Yuck.CincinnatiFiero wrote:I'd be more interested in how you made it.
However, I bet it does perform much better than the stocker, and marginally better than his previous starship enterprise.
Good to hear. I would have left it bare aluminum/polished though personally, I like the alum look. I'll have pics up shortly of the intake arm I made for Lonzo's DOHC car. Same concept.Shaun41178(2) wrote:its aluminum and tigged. All aluminum weighs much less then stock setup. TEh heaviest part on the Y section is the flange that bolts the tb.
not that you guys want to watch but I finally got streetfire to take it.
Total time to swap was about 45 minutes but I shortened it in editing to 11 min.
It runs good. I haven't put many miles or have much drive time on it. Maybe 20 minutes total and 2-3 WOT pulls but not past 5k rpm. Its needs a retune and one time at around 4500 rpm it felt like it had a dead spot in the powerband. Sort of like a power fall off but not really sure what it was. It could be a resonance issue with the intake but not sure. I haven't wound it out really to see how it pulls up top.
There is a bit less low end tq according to my butt dyno but there is still plenty there. I unknowningly left a stop sign in third gear instead of first and the car didn't stall out and pulled through without even giving it much gas.
I need to get it back to a dyno to get some logs and such but with the dyno I normally go to closed, I have to take it to another shop with a different dyno so the numbers won't be a accurate way to compare the numbers.
Boost will also be going to 14 and 16 if I can make it happen with my new injectors as my 24lbs are maxed out on the current 10 lbs
Like Steven said, it's aluminum. I learned a lot building it. Getting the flanges on the Y-pipe to mate to the flanges on the plena perfectly was actually not easy. I did eventually figure it out and now there's no mismatch whatsoever.Aaron wrote:Easy. It's a couple of boxes welded to the stock lower (But with the stock lower flanges cut off), then some pipes welded to the Y. And it's steel. Yuck.CincinnatiFiero wrote:I'd be more interested in how you made it.
Forming the aluminum to make the Y was another challenge.
On the plus side, injector swaps are now a lot easier! :thumbleft: I thought you had a set of 42's ready to go in?Shaun41178(2) wrote:It runs good. I haven't put many miles or have much drive time on it. Maybe 20 minutes total and 2-3 WOT pulls but not past 5k rpm. Its needs a retune and one time at around 4500 rpm it felt like it had a dead spot in the powerband. Sort of like a power fall off but not really sure what it was. It could be a resonance issue with the intake but not sure. I haven't wound it out really to see how it pulls up top.
I'm really interested in hearing about how all the little bits went together.
-I see you put the IAT in the end of the front plenum. Did you have a bung welded in or just tap the end plate directly?
-Did you have to change your charge pipe routing?
-Were you able to use the throttle cable bracket I sent with it or is that a different bracket?
-How'd the TB adapter work out?
-How well did the pressure ports work out?
-Overall, how easy or hard was each part and what could be better about it?
-And, of course, the big one: How does it perform? :thumbleft:
