need new clutch
Posted: Wed Sep 23, 2009 7:28 pm
so something happened to the clutch or the tranny in my whip so I am looking for something new. Basically I think the pressure plate is fubared or something jammed in it as I can't get the clutch tto disengage with the motor running. Hydraulics are fine.
So since I am taking it all apart, I am not planning on putting this motor back in. instead I plan to put the 3500 aluminum head itb setup in so I need a clutch that can hold 500 lb ft of tq at the wheels. My current held about 500 wheel for maybe 4 months but I need something stronger.
I plan to use an aluminum flywheel so that limits me to the stock sized clutch face. I am thinking spec even though I have heard mixed results. I am done with sprung clutches. I don't want to have to worry about springs popping out anymore. I can never keep it straight if its the 3+ of the 4 that is non sprung from spec
Jinx, I know you had a couple of specs right? you are swapping to a auto though now right?
I am looking to make as much hp as tq as I am going to a big cam so down low tq will be less but mid and top will be more and a slightly larger turbo then I have now so there will be a bit more lag too.
suggestions?
suggestions?
