Rocker Arms
Rocker Arms
I remember reading a while ago that GM made a car that came factory with 1.6:1 rocker arms that would fit a fiero 2.8L. It was like the 3400 or something. Can anyone confirm or deny? Also would I need different valve springs on a stock 2.8L?
Re: Rocker Arms
the first year or two of the 3100 had the 1.6 rockers that would be a direct fit to the fiero heads. They used a ball and fulcrum design. They were then changed out in the later years for pedestal mounted rocker arms that would need a decent amount of modification to get to work on the iron heads.
But yes, if you were to take 1.6 rockers and bolt them onto stock heads, they might not work too well. You would be over the max lift that the spring is rated for, so you would have to replace the valvesprings.
stock valvespring is rated at .420 max lift at the valve, and fyi the max lift on a factory fiero cam on the exhaust side is .410 at the valve.
Re: Rocker Arms
What valve springs would I want? Its $36 for the rockers from the junkyard, so thats the reason its sort of appealing. This winter I need to pull the intake to do LIM gaskets and valve cover gaskets, so I was thinking of something I could do while I was in there.
Re: Rocker Arms
I'm not sure, I'm working from memory here, but I do believe that you can use the 98111 springs from www.competitionproducts.com
- TheFieroBoy
Re: Rocker Arms
The Comp Cams valve springs part # CCA-980-12 are good for 0.500" of lift, and don't require any mods to install.
Re: Rocker Arms
.500 or not depends on installed height. If you install at 1.700", they're only good to 0.480" lift. Plus they're 3 times the price of what I suggest.
