My NEW fiero turbo setup
My old setup can still be seen here.
http://realfierotech.com/phpBB/viewtopi ... urbo+setup
I picked up some parts a couple years ago, and decided to finally get around to throwing them in this turdbucket. Here is the setup.
Setup
88 Formula no option hardtop
Wraparound Spoiler
Mustang decklid scoop
Trans
Factory 5 spd getrag (100k miles)
Aluminum flywheel
Spec 5 clutch
hi torque starter from 3400
Engine
3500 from a junkyard approx 3k miles if I remember correctly
stock crank (steel)
stock rods
stock pistons
CR with gen 2 heads yields 10.8:1
WOT camshaft 280.6/283.8 duration seat to seat, 225/227.6 duration @.050", .565/.526" lift w/ 1.5 rockers, 111 ICL, 111 LSA
Heads
GM gen 2 aluminum heads
Katech ported; 223 int, 168 exh cfm at .500 lift
Crane Gold race 1.5 rockers
Custom length pushrods.
Schneider dual valve springs
Titanium retainers
Modified gen 2 valve covers for breathers/oil fill
Fuel
Walbro 450 pump
Aeromotive adj FPR
Braided lines/AN fittings
60lb injectors(currently)
Turbo
Precision Billet 6765 E housing .82 exh
Procharger A/A intercooler(not installed)
Tial 38mm MVS Wastegate
3 inch downpipe
PLX m300 wideband
TGP exhaust manifolds
Custom crossover
Intake
Custom cast ITB setup modified for EFI
Custom sheet metal aluminum plenum (350ish ci)
Ignition
Factory distributor
MSD 8.8mm wires
Stock plugs
Crane Hi6S ignition and ps91 coil.
Battery
Odyssey PC680
ryan 3.JPG (173.3 KiB) Viewed 21058 times
IMG-20120213-00479 (Medium).jpg (88.82 KiB) Viewed 21058 times
WP_000169 (Medium)1.JPG (72.19 KiB) Viewed 21058 times
And a couple of videos
http://www.youtube.com/watch?v=LNbOXSFB ... e=youtu.be
http://www.youtube.com/watch?v=jLikjChQ ... e=youtu.be
Last edited by Shaun41178(2) on Fri Jun 02, 2017 11:11 am, edited 5 times in total.
Re: My NEW turbo setup
What are you using to tune it?
CincinnatiFiero
Post by CincinnatiFiero »
That intake is bad ass, very cool setup.
Are you going to spray on this setup?
Stock computer is running it with a chip
Nitrous will be used on this too
Someone's off the shelf chip or a custom burn?
Going to go with a Moates Ostrich and TunerPro RT?
Megasquirt?
jdv
Post by jdv »
Nice work, looks better than the last time I seen it . When are you going to step up to the 7730/7165?
its a custom prom by Ryan at Sinister performance
http://www.gmtuners.com/
I will not be going with a megasquirt nor a moates or ostrich. Not sure when I will swap to a 7730 if ever. I shall see how it runs on the factory computer first before trying something else. I have proven however it will run with the factory computer. Idle anyways.
Does it have a cold air intake?
Shaun41178(2) wrote:its a custom prom by Ryan at Sinister performance
I @$$ume you have plans to iteratively tune it and you're not expecting that tune to be spot on right out of the box...
cai intake = yes
future tuning = yes
Neat! how close is the crossover to the distributor? I had some heat related problems with mine.
My crossover follows the same route as a stock crossover. I am a le to use 2 of the factory crossover heatshields and the third just needs a slight tweak to make work because of the expansion joint.
I will post up more pics shortly showing more details
These pics show the crossover in a little more detail.
IMG00370-20100629-2237 (Medium).jpg (54 KiB) Viewed 20812 times
IMG00356-20100629-2125 (Medium).jpg (68.33 KiB) Viewed 20812 times
IMG00410-20100713-2149 (Medium).jpg (45.48 KiB) Viewed 20812 times
Damn, perfect crossover. I mean it's not equal length and still uses factory manifolds, but for what it is it couldn't be any better. Very nicely designed and implemented.
Ditto; looks very well packaged.
A donut would have made it a good bit easier to make that tight bend at the turbo connection.
Do you have any other brackets supporting the turbo?
jdv
Post by jdv »
Very nice work.Now lets hear it run.
Are you running a TGP rear manifold?
I don't have any brackets supporting the turbo right now but it won't be hard to make one real quick. I just haven't gotten around to it yet. I am also running a rear TGP manifold. Basically the TGP manifolds are just like the stock v6 fiero logs. The both point towards the transmission allowing for a crossover pipe to be used. The TGP manifolds share the same bolt pattern as the 3400 and 3500 heads.
i used the flanges from the TGP crossover, and modified a pair of 3400 crossover pipes to make my crossover. here are a couple more pics of it.
IMG00339-20100617-0122 (Medium).jpg (50.27 KiB) Viewed 20773 times
IMG00338-20100617-0122 (Medium).jpg (57.31 KiB) Viewed 20773 times
IMG00358-20100629-2125 (Medium).jpg (49.09 KiB) Viewed 20773 times
posted by jdv
Bottom of the first post are links to two videos of it running.
Here is what I did for the coolant. Since my intake didn't have any sort of thermostat housing provision, I had to come up with something else. There were already two holes drilled in the intake for cooling in these locations. I drilled two more on the other side and added AN fittings.
IMG-20120108-00410 (Medium).jpg (75.07 KiB) Viewed 20772 times
I fabbed up a canister of sorts to fit where the stock Gas tank evap can was located. I used a Moroso screw on cap to fill my coolant system and made sure it was the highest point in the system. I welded on one -12 AN fitting to run to my heater core line, and out the bottom is the hose feeding the drivers side hard coolant pipe that runs to the radiator. I elminated the crossover coolant tube that runs on the backside of the engine in a stock v6.
WP_000117 (Medium).jpg (72.54 KiB) Viewed 20772 times
Then I used pushloc hose and fittings and ran it to the fittings on the intake manifold.
IMG-20120529-00605 (Medium).jpg (99.53 KiB) Viewed 20772 times
Braided -3 oil feed and a braided -10 return. i am also running a remote oil filter. The oil feed was "T"d off of the oil pressure sensor location which you can see in the pic below in the upper right corner
I picked one of these up off ebay to use on the oil feed side of the turbo. it just bolts right on.
This for the oil return.
IMG-20110713-00061 (Medium).jpg (57.7 KiB) Viewed 20772 times
