Shop Equipment...
Shop Equipment...
I've been thinking about my long term goals in life lately, and I have decided that I need to set up a budget, and plan for what I want if I ever intend to get it. I would like to start saving up to buy tools and equipment for a legitimate workshop.
Some of the tools I'm thinking would be necessary, at least for a good foundation, are as follows:
Lathe
Mill
Welders(TIG and MIG)
Cutting torches
Plazma cutter (table style)
Car Lift
Big compressor
Additions:
tubing bender/notcher
parts washer (industrial dishwasher?)
oven
fridge/freezer
Does anyone see anything major not listed?
Does anyone have any recommendations of equipment to look for? Features? $$$ to spend?
I've been piddling on fleabay and see Milling machines starting (used) at about $1275, so I'm figuring 6-7K for something accurate and reliable,
I know prices fluctuate over time, so I'm really just trying to get a ballpark figure to run off of. so I can start setting goals to achieve.
All thoughts are appreciated.
-Eric
Re: Shop Equipment...
Tubing bender.
Tube end profiler/notcher (for shaping round tubes prior to welding)
Flow bench?
Are you looking for a CNC mill or a manual mill? If manual, a basic Bridgeport is as good as it gets. I have a Bridgeport with 3 axis CNC conversion (table + power quill feed) in storage, but I don't know much about other CNC options.
A LOT of tool boxes/cabinets. They add up. If you're planning to build up a work shop and *get work done*, you'll need to spend a lot of effort making sure its organized so you're not wasting time looking for tools, parts or materials that you know you have.
Red up on "lean manufacturing".
fieroguru
Post by fieroguru »
My first recommendation is to list all the projects you would like to do or be able to do in the future. Many items on your list come in a vast array of sizes and you need to make sure your purchase will work and not need upgrading in a short period of time. I would also recommend you focus on finding good used equipment vs. buying new. For a hobby/part-time use good used equipment is a good balance between investment costs and capability.
Lathe: Smaller ones spin faster for small pieces and the larger ones spin slower. So if you are going to turn some 1” shafts, a smaller lathe will be faster than a larger one. I have a 9” Southbend bench top lathe with 36” bed and it works well for most items, but I am also looking for a 16” lathe for flywheels and other larger items. A 10” lathe with the largest through hole is probably the best compromise if you are only looking for just one lathe. Make sure it has a selectable gear box for the power feeds vs. needing to swap gears as well as the taper attachment. The name brand ones also will have power feeds in both X & Y directions. You can find a 9-10” lathe in the $750 to $2K range. Tooling and chucks are expensive, so don’t be afraid to pay more if it comes with more tooling.
Mill: Vertical Mill is what you are looking for (there are Horizontal ones as well). Again there is a vast range of sizes and styles. There are quite a few bench top models that are fairly light, easy to move and run on 110V. However, these won’t have the table travel for larger items so you may be required to do multiple setups. The head position might not be as adjustable as well. I have a Lincoln (Bridgeport Series 2 knock off) with a 50x12 table, 35x17 table travel, 3HP 3 phase variable speed head (reduced to 2hp due to static phase converter), articulating head (can pivot front to back, or side to side), with x-y DRO and power feed in the x direction. Paid $1100 for it on Ebay and had to drive to Pittsburg to get it. These larger mills take up quite a bit of space and can weigh up to 4K lbs, so they aren’t the easiest to move. Many of the older larger machines have more features than a newer cheaper version today. If it is a name brand or a knock-off, then you can also get CNC conversions for it later on. There is a series 1 knock off CNC vertical mill for about $4500 near me that I would like to have, but no room at the moment.
Welders(TIG and MIG): Stick with a name brand that is supported by your local welding supply shop, as you will want to be able to have it serviced when needed. I would get 220V versions for both, and buy a RV power cord and swap ends so you can use your welder anywhere in the garage and even a short distance into the driveway. Start with the MIG as it will be a lower initial investment. Many newer MIGs come with a spool gun for aluminum, so you can get by w/o the TIG for a while. Many of the lower end TIGs won’t work on aluminum very well, so if you want to weld aluminum make sure your model will do that. If you plan to weld mild steel, stainless steel and aluminum, you will have 3 welding gas bottles to store as well. I only have a MIG – Lincoln ProMig 175 220V purchased at Lowes with a 20% off coupon for about $500 with cart as well.
Cutting torches: Only needed if you are going to cut/bend really thick steel. This tool is one of the largest causes of garage fires… I had one for 3 years, but never used it and turned back in the bottles when I moved. I don’t really need one.
Plasma cutter: Again stick with something that can be serviced locally and get the largest one you can afford (220V). I would prefer the plasma cutter setup on a 4x4 or 4x8 table so you can cut brackets either via CNC or with an optical copy cat setup (draw part with a sharpie and camera follows the line to cut the part). Just make sure to look closely at the specs and how much time it takes to cut 1” of travel in 16ga, 1/8” or larger. Many of the 110V models are really, really slow. A Sawsall or 4 ½” cutoff disk on a hand held grinder will accomplish the same for lower initial costs –these are what I use, but they are hard on the joints in your arm long-term.
Car Lift: Lots of options, but if you want the most versatile lift, then stick with a twin post. Asymmetrical twin posts give you more room to open the doors, but the symmetrical ones are lower cost. There are styles with the hose and cables running along the floor (under a ramp plate) as well as overhead (which keeps the floor flat and smooth, but might need taller ceilings). I wouldn’t get one lighter than 7K lbs for general use as many trucks are 6500 lbs or more. I purchased mine used (Grand, 9K, symmetrical twin post, floor mounted cables/hose) from a muffler shop when they upgrades to 4 post lifts for the large diesel trucks. You can usually find used lifts for $500+ on craigslist.
Big compressor: Mine is a 220V 5hp w/60 gallon take with a single stage pump ($400 new), but there are smaller and larger options and even dual stage compressors for even higher CFM and pressure. If you can listen to the compressors run, spend more for one that runs quieter… or plan to partition it off. Also look at an air dryer or a water/oil separator. Some will say you need an oiler for your air tools, but if you oil them manually from time to time you don’t need it (and it keeps oil out of your hoses).
Depending on what you want to get into, you might think about adding these tools as well:
Heavy duty vice: I use mine all the time and have gone through a couple of them . Many times I use it with a hand held mini sledge hammer, so make sure it is large and heavy. It also helps if the jaws will separate more than 6” as I use it for a small press as well.
Heavy duty work table/bench: Either metal or wood. I have a metal one that is about 5x5 and about 30’ of wood benches bolted to the walls (2x6 frame, ¾” plywood, then ¾” oak hard wood flooring on top).
6” belt sander: good for flattening exhaust flanges or smoothing cuts on longer parts. The 6” ones are typically longer than the 4” ones and the 4” ones are too short for a SBC flange to be 100% on the flat part of the belt. I have one of each.
Vertical Band Saw – I have a 14” Rockwell vertical band saw that was setup for wood. I have collected everything to pulley it down to be a steel version, but haven’t made the time to do the conversion. So far I have about $200 in it, but it is an older model that is very heavily built. Vertical band saws are better for cutting brackets and easier on your arms/elbows vs. the sawsall.
Sheet Metal Shear: mine is a 36” Pexto 16ga foot shear (about $200-$750 used), but I would like to upgrade to a 60” one ($800 - $2500).
Metal Brake: Mine is a 48” homemade version, but isn’t a box pan brake. I would like to upgrade to a 60” box pan brake ($1500 – $3000).
Hydraulic Press 12-20 ton: they come in handy for pressing parts together or taking them apart. Can also be used to bend 3/16 to ¼” steel for brackets if you have the right dies.
Tubing Bender: I would like something that will bend up to 2” round tubing w/o any kinks. Something like a JD2 manual bender or even the air over hydraulic. A tubing notcher to go along with it would be nice as well.
Large Sand Blasting Cabinet: I would like one large enough to fit the rear cradle in.
Large electric oven: for powder coating. I will probably build a large enclosure and cannibalize a craigslist oven for the heating elements and controller.
An industrial dishwasher makes a great parts cleaner, especially if it can fit entire cylinder blocks, heads, intake manifolds, oil pans, etc.
Deep sink.
There's synergy in some of the tool selections, also. With a CNC plasma and a brake, you can build a custom sheet metal monocoque body... if you have the design skill and patience.
Ditto on the cutting torches... very rarely necessary if you have the other cutting equipment. Mostly useful for removing rubber bushings and heating seized fasteners. I find that most of the time, proper prior planning via the application of penetrating oil well ahead of time frees all but the most horribly seized fasteners.
The Dark Side of Will wrote:Tubing bender.
Flow bench?
Flow bench was another one I would like to get, or build.
all good suggestions, tubing bender/notcher will be added to the list. I was planning on getting a manual mill, and then in the future getting a conversion kit.
fieroguru wrote:My first recommendation is to list all the projects you would like to do or be able to do in the future.
that could get dangerous... :crazy:
as a general rule, I like to do everything with my own two hands rather then pay someone else. not because I'm cheap, but because I enjoy being able to say I did it.
That being said, I like doing engine swaps, fabricating mounts and brackets, headers, porting, custom manifolds, ect. I wouldn't mind getting into custom suspension work too, but that's a spot I just don't know much about.
I also want to have the capability to cast aluminum parts up to the size of an intake manifold.
fieroguru wrote: Many items on your list come in a vast array of sizes and you need to make sure your purchase will work and not need upgrading in a short period of time. I would also recommend you focus on finding good used equipment vs. buying new. For a hobby/part-time use good used equipment is a good balance between investment costs and capability.
Good used equipment was definitely in the plan, as was capacity, I wouldn't want to have to do 3 setups to machine one part...
fieroguru wrote: Lathe: Smaller ones spin faster for small pieces and the larger ones spin slower. So if you are going to turn some 1” shafts, a smaller lathe will be faster than a larger one. I have a 9” Southbend bench top lathe with 36” bed and it works well for most items, but I am also looking for a 16” lathe for flywheels and other larger items. A 10” lathe with the largest through hole is probably the best compromise if you are only looking for just one lathe. Make sure it has a selectable gear box for the power feeds vs. needing to swap gears as well as the taper attachment. The name brand ones also will have power feeds in both X & Y directions. You can find a 9-10” lathe in the $750 to $2K range. Tooling and chucks are expensive, so don’t be afraid to pay more if it comes with more tooling.
Very helpful as usual, thank you, I didn't know much about metal lathes. this is something I need to research in depth, I've used wood lathes several times, but never a metal lathe.
fieroguru wrote: Mill: Vertical Mill is what you are looking for (there are Horizontal ones as well). Again there is a vast range of sizes and styles. There are quite a few bench top models that are fairly light, easy to move and run on 110V. However, these won’t have the table travel for larger items so you may be required to do multiple setups. The head position might not be as adjustable as well. I have a Lincoln (Bridgeport Series 2 knock off) with a 50x12 table, 35x17 table travel, 3HP 3 phase variable speed head (reduced to 2hp due to static phase converter), articulating head (can pivot front to back, or side to side), with x-y DRO and power feed in the x direction. Paid $1100 for it on Ebay and had to drive to Pittsburg to get it. These larger mills take up quite a bit of space and can weigh up to 4K lbs, so they aren’t the easiest to move. Many of the older larger machines have more features than a newer cheaper version today. If it is a name brand or a knock-off, then you can also get CNC conversions for it later on. There is a series 1 knock off CNC vertical mill for about $4500 near me that I would like to have, but no room at the moment.
I was thinking about trying to find an older bridgeport and doing a CNC conversion. the mill and the lathe are the #1-2 on my list because with them, I should be able to accomplish quite a bit.
fieroguru wrote: Welders(TIG and MIG): Stick with a name brand that is supported by your local welding supply shop, as you will want to be able to have it serviced when needed. I would get 220V versions for both, and buy a RV power cord and swap ends so you can use your welder anywhere in the garage and even a short distance into the driveway. Start with the MIG as it will be a lower initial investment. Many newer MIGs come with a spool gun for aluminum, so you can get by w/o the TIG for a while. Many of the lower end TIGs won’t work on aluminum very well, so if you want to weld aluminum make sure your model will do that. If you plan to weld mild steel, stainless steel and aluminum, you will have 3 welding gas bottles to store as well. I only have a MIG – Lincoln ProMig 175 220V purchased at Lowes with a 20% off coupon for about $500 with cart as well.
I already have a Lincoln Promig 180 back home, whether it'll still be mine or not when I need it... Me:"hey dad, where's my welder" Dad:"that's my welder don't you remember? :pardon: " I was aware of the gas bottles, learned about that when I bought the Promig. I'm really wanting to get a good TIG, hopefully by the time I am ready to pull the trigger prices on these will have come down some... I'm not holding my breath though...
fieroguru wrote: Cutting torches: Only needed if you are going to cut/bend really thick steel. This tool is one of the largest causes of garage fires… I had one for 3 years, but never used it and turned back in the bottles when I moved. I don’t really need one.
didn't realize they weren't as useful. might get taken off the list then.
fieroguru wrote: Plasma cutter: Again stick with something that can be serviced locally and get the largest one you can afford (220V). I would prefer the plasma cutter setup on a 4x4 or 4x8 table so you can cut brackets either via CNC or with an optical copy cat setup (draw part with a sharpie and camera follows the line to cut the part). Just make sure to look closely at the specs and how much time it takes to cut 1” of travel in 16ga, 1/8” or larger. Many of the 110V models are really, really slow. A Sawsall or 4 ½” cutoff disk on a hand held grinder will accomplish the same for lower initial costs –these are what I use, but they are hard on the joints in your arm long-term.
I don't care for cut-off wheels, too many close calls with them. I didn't know they made optical copy plasma cutters, that's pretty cool. I hadn't considered one on a table like that, but it makes sense. as far as plasma and welders go, I wouldn't consider anything less then 220v anymore.
fieroguru wrote: Car Lift: Lots of options, but if you want the most versatile lift, then stick with a twin post. Asymmetrical twin posts give you more room to open the doors, but the symmetrical ones are lower cost. There are styles with the hose and cables running along the floor (under a ramp plate) as well as overhead (which keeps the floor flat and smooth, but might need taller ceilings). I wouldn’t get one lighter than 7K lbs for general use as many trucks are 6500 lbs or more. I purchased mine used (Grand, 9K, symmetrical twin post, floor mounted cables/hose) from a muffler shop when they upgrades to 4 post lifts for the large diesel trucks. You can usually find used lifts for $500+ on craigslist.
I started pricing lifts, I was honestly surprised by the price, I thought they would be quite a bit more then they are.
fieroguru wrote: Big compressor: Mine is a 220V 5hp w/60 gallon take with a single stage pump ($400 new), but there are smaller and larger options and even dual stage compressors for even higher CFM and pressure. If you can listen to the compressors run, spend more for one that runs quieter… or plan to partition it off. Also look at an air dryer or a water/oil separator. Some will say you need an oiler for your air tools, but if you oil them manually from time to time you don’t need it (and it keeps oil out of your hoses).
i've never run an oiler on my air tools, I just oil them as i go. I can see where an oiler would come in handy depending on what tools you're using, and how frequently you use air. I was thinking a 60-80 gallon, and on it's own pad off of the shop to keep the noise down.
fieroguru wrote: Depending on what you want to get into, you might think about adding these tools as well:
some of these last few items I was thinking about today, the oven, and brakes. I like the idea of using a craigslist oven. I also though about making a hot tank of sorts, get a couple of hot tub elements, or hot water heater elements, and put them in a 55 gallon drum with a small pump.
the press and the vice also came up today, nothing like having a good vice, and a press is much more versatile then I could imagine.
The Dark Side of Will wrote:An industrial dishwasher makes a great parts cleaner, especially if it can fit entire cylinder blocks, heads, intake manifolds, oil pans, etc.
Deep sink.
I like the idea of the heavy duty dishwasher, I thought about that before I joined the navy for the shop I was going to build back home. hot water does a damn good job of cleaning things.
Deep sink is another good one, but that will go more into the design of the actual shop.
surprised nobody has mentioned a beer fridge yet... :P
Started thinking about this stuff again, bought a Miller Diversion 180 TIG a while back, also started buying materials to make a furnace for melting down aluminum. pretty soon I'm gonna start looking into getting a mill, it'll be necessary if I get deep enough into casting parts.
slowpoke
Post by slowpoke »
Chainfall/overhead crane
slowpoke wrote:Chainfall/overhead crane
Absolutely.
I'm saving my pennies for rolling door for my garage, which will free up ceiling space for me to install a manual bridge crane.
yeah, thats definitely something I plan to put in. on base here in charleston, there's a shop with 2 big CNC mills, and a big gantry crane setup my mind exploded when I saw the place. what I would do for a shop like that.
in other news, I'm going to look at a mill and a lathe later today... wish me luck!
My dad has an I-beam running down the middle of his garage with a beam trolley and a chain hoist. That's extremely handy itself, but I'm really looking forward to having my bridge crane :wink:
so, I'm getting an older mill and lathe, the lathe is a Clausing, the mill is a Steinel ("Made in Western Germany") they're gonna need a little work, but I'm getting a pretty good deal on them. I'll post pics when I get them to the house.
and so it begins...
Steinel SV4 Mill.
Intake manifold from PFR on the table.
Note the "made in Western Germany" tag... LOL.
it's a little stiff, but everything moves, I'm gonna keep cleaning and oiling and see what I can get out of it. later this week, or maybe this weekend, I'm gonna wire in a 220 V outlet, and my 3 phase converter and see how this puppy rolls.
The Dark Side of Will wrote:http://www.lowbucktools.com/
Thanks for the link, Lots of cool stuff in there!
never seen one of these before, it's brilliant. a simple jig for spacing rivets or screws.
http://www.cleavelandtool.com/Fan-Space ... hHetflVikq
Well, after wiring in a 220 V outlet, and a 1-3 phase converter, and way too much shenanigans, the mill lives... and I'm happy to say, I only shocked myself once(JK), and I still have all my fingers. I haven't tried cutting any metal yet, as the table isn't fully re-assembled from my cleaning and re-greasing operations.
There are two layers of paint on the machine. I really hate whoever did the top layer, as they just painted whatever the hell they wanted to, whether they should have or not. both layers are grey, one layer darker than the other. I noticed most pictures of the Steinel mills show green, I have yet to see any green paint. a repaint is planned, but very low on the priority list.
The quill lock right now, is a bolt shoved through the hole where the handle goes, thankfully it's not frozen. I plan to fix this, ideally by getting a new lever. I also need to replace the belts, they are in terrible shape.
so I got rid of the mill and lathe I picked up, they needed more work than I had time to give, I'm still in the market for a mill and lathe, but they're lower on the priority list. I'd like to pick up a 3d printer first, and have been eyeing up a few options
https://www.creality3d.shop/collections ... QAQAvD_BwE
https://folgertech.com/?gclid=CjwKCAiAs ... REQAvD_BwE
I like the folger tech unit a little better than the CR-10, it offers a larger build volume, and the box frame should be more rigid. it's also less expensive than the CR-10.
in other news, I bought a house with a small 2 car garage, I'm trying to make the garage as modular as possible, with most everything on wheels, and able to be easily moved. I picked up some wire racks, and a caster kit from lowes. I set them up with a large-ish space on the bottom, for tools with cases, two smallish spaces for some bins I acquired from work, and a large space on top, that I lined with peg board so I could hang up consumables in easy reach, and keep everything neat and organized. Because the whole thing is on casters I can put stuff on both sides of the pegboard(infrequently used stuff on the back). I'm also working on a storage solution for TIG filler material, I'll post pictures when I get it finished.
I picked up two air compressors yesterday, one was free, one was $50,
Freebie, had a busted drain valve, which was stupid easy to fix, installed the new drain, plugged it in, and it worked great. the major downside to it, was that it was tiny, 8 gallon, 2 hp. I picked it up hoping I could trade it around to get other tools.
comp 1.jpg (97.11 KiB) Viewed 2135 times
then I saw this on craigslist for $50!
comp 2.jpg (98.21 KiB) Viewed 2135 times
the cycling switch is toast, but, turns out, the free compressor I just picked up has a good one! I need to see what it says for current ratings, if it will support, I'll swap it, if not, I'll find a replacement and swap it out. I'll call it a win.
I'm going to build an aftercooler and moisture separator inline between the compressor and the tank, ideally as a free standing unit so the vibrations of the compressor are isolated from it. I'll post pictures of the ideas later.
Great find with the compressors!
My prior house came with an electric push mower that didn't work. It took me a couple of minutes with a meter to figure out that the rectifier was dead. $12 later I had a rectifier on the way. When I installed it I had a $12 mower.
hell yeah!
I'm finding new pressure switches run about $10-30, some of the higher priced units come with a new pressure regulator too.
the aftercooler I'm planning, will be designed to be quick disconnect to ensure the compressor remains portable, I want the cooler to be isolated from any vibrations the compressor puts off, to further help and entrained moisture fall out of suspension. I'm also going to add a receiver to the setup, with a separate dryer. the receiver will drop the velocity of the air, and allow the moisture to be deposited there, instead of the tank. it will need to be drained periodically, but I'd rather that than the tank. the hard part right now, is finding a suitable air to air heat exchanger, alot of people use transmission coolers, but I have yet to see a pressure rating for one. I may look into an A/C condenser, if the operating pressure is >150 PSI.
