4T60-E Swapped for an 08 4T65-E?
Posted: Sat Jun 06, 2015 5:23 pm
by Identity Crisis
I am installing into my Fiero a 92 3.4DOHC and it has the 4T60-e Transmission.
I have a spare 08 Grand Prix w/NA3800 and the 4T65-E trans.
Is it worthwhile swapping to the newer Transmission?
Re: 4T60-E Swapped for an 08 4T65-E?
Posted: Fri Jun 12, 2015 9:19 pm
by nocutt
Identity Crisis wrote:I am installing into my Fiero a 92 3.4DOHC and it has the 4T60-e Transmission.
There are a lot of big changes with that vintage transmission and the 65-e...assuming you get over the hardware issues...axles, perhaps TC and flex-plate (not sure) you still have to use a compatible PCM...definitely not the '92...then there is the wiring harness. Worthwhile? Yeah if it means a lot to you...plus newer transmission hey
![Yahoo! :Yahoo!:](./images/smilies/yahoo.gif)
Try to get hold of Ryan (Darthfiero) on the other board; he is the only person I know who will be very conversant about this...lol because more than likely he may have already completed a blue-print or in the process...
Good luck
