So now I have torn the engine down, all the bearings look great, like they are almost brand new.
Started to clean the block up, deburr it, enlarge oil passages and stuff like that. The block weights 60lbs.
![Smile :)](./images/smilies/smile.gif)
I am gonna upgrade the rods, pistons and rings. That will handle up to 400 hp, though I won't be making more than 300. Plan on lightly porting the heads, nothing too major just a good cleanup, 5-angle valve job, new SS valves and then assemble it and get it running.
As for mounting it, it will just take 4 mounts, or more if I want to. Shouldn't be too hard to get in place, just need to get axles that will fit the tranny and the Fiero hub.
I plan on down the road, 2 months or so, to turbo it. Around 8-10psi, nothing huge, considering this engine will weight at least 100lbs less than the Duke, and be making about 240-270hp. Should be fun!
I will post some pics on here, but for now, here are some uploaded pics on Webshots. Ciao
http://community.webshots.com/album/493910615XzzZFw/0
