What number is this connector?
Posted: Sun May 24, 2020 4:51 pm
See circled. It's just under the ecm. The wires from here share the same bulkhead connector as the ecm wiring. NOT the c203.
I want to know what wires run through here.
- 20200524_161533~2.jpg (565.57 KiB) Viewed 600 times
Re: What number is this connector?
Posted: Sun May 24, 2020 4:53 pm
it definitely looks like every other C203 I have ever seen. I just took one apart yesterday.
Posted: Sun May 24, 2020 4:56 pm
The c203 is on the bulkhead right? Thats what I thought
If what you say is true then what is the bulkhead connector on the passenger side running to the c500 numbered?
Posted: Sun May 24, 2020 5:08 pm
The part on the bulkhead isn't actually a connector, it's just a grommet with lock tabs. it's stuck together with something that appears to be hot glue like you can get at a craft store. you can see in the first picture there's nothing around my wiring, and in the second, the pass throughs are installed. no wires were cut/crimped to install them, they just clamshell over.
Posted: Sun May 24, 2020 5:11 pm
From the 1985 FSM
EDIT:
Here's a more complete view to show the arrows on the bulkhead are for splices not connectors.
Posted: Sun May 24, 2020 5:30 pm
Got it. I thought the connectors on the bulkheads had a number too. Appears they don't. Thanks for the info
Posted: Sun May 24, 2020 6:09 pm
Shaun41178(2) wrote: ↑Sun May 24, 2020 5:30 pm
no prob. the pass through is fairly easy to disassemble, the locks are all visible on the outside, just carefully heat it up with a heat gun and the glue will give pretty easy.
