Aluminum Radiator question.
Ok, so the time has come to upgrade the radiator in the 88. I still have the factory radiator in the car and the car was a 4 cyl. Now that I have an engine swap I figured I should get a new radiator. I'm not sure of the size of the stock radiaotr, but I remembered reading that this radiator would work.
http://store.summitracing.com/default.a ... search.asp
Anybody know for sure if this will work? Any better options out there?
Thanks!
Thanks!
The original fiero radiator is 24.5" x 16.5" overall. 1 5/8" thick core. In *theory* it should drop right in, you might have to massage the brackets a bit. It's the closest thing I've found to a drop in alumnium replacement radiator...
However, one thing I noticed when I first saw that radiator, is that it is only a single row... Now it will easily out-cool the stock radiator. Actually the corvette radiator is about the same size, and those are good for 400+hp. I've been running the stock radiator for a while now with ~330hp, with only limited problems with the temp creeping up on really hot days.
I really like the prices/dual rows of the trukool radiators, but damn, they're 19" tall!
http://www.speedwaymotors.com/xq/aspx/p ... roduct.htm
Sure will! :thumbleft: It will probably be a few weeks before I install it. I ordered it today but want to take the car to work to install it. If this damn ice/snow/cold weather would go away I'd be driving my car....Series8217 wrote:Fast88Fiero, could you weigh the factory Fiero radiator and the aluminum radiator if/when you get it? I'm interested in this for weigh reduction purposes.. the 4cyl radiator is currently cooling my 3.4 DOHC fine, even at the track.
I think the aluminum radiator holds a little more coolant because it's slightly larger. Probably the extra weight in coolant will equal the two out.Series8217 wrote:Thanks for the info!Fast88Fiero wrote:Just got the factory reman radiator for the 86GT. It weights 9.75lbs on our shipping scale at work. So the aluminum radiator is 2.75lbs lighter.
James
I had no idea our radiators were so light already! Does the aluminum radiator have the same coolant capacity?
Only 68.....you suck! It was 25 here today. It's about 12 out right now. I'm ready for summer!!S8n wrote:I hear you about the weather....high here today was only 68!! I was freezing my ass off.Fast88Fiero wrote:LOL. Hell no. Weather here sucks ass. It's too damn cold. If it ever warms up I'll drive the car to work and put it in. :thumbleft:
I'll be sure to take pictures of the install when I get to it and post them up. :thumbleft:
