FS / WTB (7-03-06)
FS / WTB (7-03-06)
i need the fallowing parts for the 3.4 DOHC (91-93 unless noted otherwise). ill be looking on ebay and local yards as well, so ASAP would be great!
starter
fiero V6 front motor mount bracket
clutch master/slave cylinder
exhaust cross over
Twin Dual Cam / Dual Over Head Cam (beauty cover)
starter
exhaust cross over
Last edited by slow'n'steady on Mon Jul 03, 2006 4:48 pm, edited 7 times in total.
yeah i have spare #30s still, and #42s on my engine now. I want bigger... #50s would be good. #60s would be betterShaun41178(2) wrote:WTH donk I didnt' know you had 42's laying around. I even thought I asked you about that. I know you said you had 30's. YOu looking for 50's now?
Resident Import Elitist
1991 Skyline GTR
(OO\ SKYLINE /OO)
1991 Skyline GTR
(OO\ SKYLINE /OO)
I have the alternator from my 1992 Z34 5-speed before I swapped engines, the car had 110k on it and the alternator was tested and working properly, actually outperforming the factory rating for it. Make an offer.
What year valve cover do you need, and front or rear? I probably have it too, make on offer.
I only have 1 front 94-95 valve cover, and it has the death sentence already. I am ruining the enitre piece just for the gasket liner underneath on the corner so I can use a rear cover for the front. Call me anal, but I liek the rear valve cover better, and will do a lot to make it work, even with 94-95.slow'n'steady wrote: Aaron: i need both 94-95 valve covers (unless 91-93 will fit the 94-95 carriers, then ill only need the front one) LMK if you have em, and ill shoot you a price for them and the alt.
Anyways, back to the point...I don't have a 94-95 front, but if you have a 94-95 carrier you need a 94-95 cover. On a side note, 96-97 valve cover will also work, but their oil fills are in a slightly different location. Not a big deal though, you can use any 94-97 cover on any 94-97 carrier.
As for the rears, they don't matter. All 91-95 were the same, and 96-97 were the same except they didn't have the breather nipple, it only ran a single breather line from the front cover, unlike 91-95 which ran dual breathers, one from each cover. If you are using a 91-95 upper intake, any rear valve cover will work. If you are using a 96-97 upper intake, you need a 96-97 rear valve cover.
This being said, I have an extra 91-95 rear valve cover with the breather nipple. Let me know..
Hey, I'm picking up a '94 motor on Wednesday... I should be able to help you out (at the very least) with an appropriate manifold, valve-cover, and crossover. I'll have to double-check, but I'm 99% sure they should work fine (most of the hard-part changes were 96+... 94 was the ODB1.5 series with some different sensors but same engine, iirc)
The starter and alternator are unknowns...
I'll let you know.
I'll let you know.
STILL NEED
starter
exhaust cross over
starter
exhaust cross over
Last edited by slow'n'steady on Tue Apr 11, 2006 11:01 pm, edited 1 time in total.
