Is the front compartment wall structural?
As far as I can tell, the front trunk wall serves no structural purpose; its just there to make a sealing edge for the front compartment. Its flimsy sheet metal. With the tire tray out I can bend it with my hands. I cut the top part off to clear my hood scoop; now its even flimsier. It isn't directly tied to the frame rails or suspension. Am I missing something? Is there any reason I can't hack this thing out and not worry about replacing it with anything but fiberglass? If I'm wrong and it is reinforcement for something, am I going to have any benefits from replacing it with something stronger (after I hack it out)?
I think you guys may be right. Going back to my wiggle test, I tried it again and found that I can't deflect it along the length of the car. Makes sense, right? I can twist it but it seems to be loaded laterally, keeping the frame rails from coming together a bit or twisting up toward each other. I'll leave it in place for now.
It looks easy enough to add a bar across the frame rails up front. There's nothing in the way. I may weld or bolt in something when I have some daylight again. If that front compartment wall really does add some rigidity I don't know that it really does enough..
Front trunk wall = forward wall of trunkSeries8217 wrote:...front trunk wall...
Anyway, the forward wall of the front compartment is structural, IMO, because it ties the front frame rails together. Now, I'm pretty sure there are better ways to do that which would compromize front compartment space, but I haven't really looked at things.
I am doing a hood vent right now too, and I am going to cut about 1-1/2" down, 22" wide section out of the center of that wall. being its curved, it cant actually be doing a whole lot. any side-2-side load would just bend the curve. and, I am also going to cut the two 1-1/2" cuts, and fold it over, so if anything, it will actually be stronger. but, no I dont think its structural. at least in a chassis stiffning kind of way. I think its just somthing to bolt the coolant overflow, & tire tub too.
the front cross member is your front stiffness.
Mines has been gone for years, back when installes a 12 in a bandpass box up there. It handles the same, and IIRC, it is so thin and not very sturdy, doesnt seem like that wall was ther for anything but a divider. If it was for structural purposes, I would have figures they would have made it beefy as hell, like the one out back.
XzotikGT
1987 GT+1996 3.4 dohc+To4b+water injection
