His email is onephatprix@hotmail.com if anyone needs anything. The only part I took was the oil cooler and the serpentine tensioner.Matt wrote: I have a '95 DOHC engine here .. complete
dropout (trans, complete engine, coolant lines, wire harness, ecm, etc...).
The lower and upper intakes are spoken for at the moment, but if that changes, I'll let you know for sure.
Wire harness:
As far as the harness condition, the only thing on there is I had to cut
that pig-tail off that the fans connect into. That part on the front o fthe
harness that runs along the front frame of the car. I needed it another
engine swap. I did accidentally clip ONE wire while I cut that connector
out, but I can solder that up if you want me to (?). Other than that, the
rest is 100% COMPLETE.
I can get you pictures of anything as well. Give me a holler if you want
anything off of this!
Thanks
Anyone need any parts from a 95 DOHC?
I had a guy email me concerning a REALLY old post I made over at the W-body forums. He recently pulled a 95 DOHC out for a L67 swap IIRC. Here is the email:
I am searching for a good transaxle for my rebodied Fiero. I have a Getrag 282 and drove it without the dog bone. The 3800 has a lot of torque and it twisted the mounting ears off of the transaxle. I would like to replace the entire transaxle and mounts if you have them available.
My emails is newmdav@ispwest.com
Thanks,
Dave Newman
Tampa, Florida
727-773-7665
Thanks,
Dave Newman
Tampa, Florida
727-773-7665
Real Talk, Real Solutions.
