What happens when your parts bin math is off?
This:
http://www.fiero.com/forum/Forum2/HTML/076528.html
I feel really bad for this guy. Alot of money down the tubes. I'm not sure what he did, but I have a feeling he might have upped the rocker ratio. There's not any mention of a new came or heads.
oops! :thumbleft:
For people like me who feel dirty clicking a link to that site:
Well last week will out on a test drive, there was a small noise from the engine area sort of a rotating type sound and then it stopped. Luckily I was not far from home, the engine would not start, seemed to be locked up, anyway I got the car home via a AAA flatbed. This weekend I pulled the engine to see what was going on, taking the engine out a 2nd time is certainly easier, anway the trans seemed fine, rotated with no noises or any apparent issues. So it must be the engine, see the pictures below of the engine and my new Voretc heads !!!!
In the engine pic you may be able to see the head of 1 of the inlet valves, just below the big hole in the piston !!
I had been having a problem with the engine not wanting to rev much past 3000rpm, I noticed that all the pistons had marks from where the inlet valves had been touching them, I had assumed I would have pleanty of clearance, I assumed wrong. At least I now know what the problem was, for anyone else reading this be warned check your piston to valve clearance. As for my engine I am not sure what to do, should I just buy a fully assembled crate engine or try and re-build, my coidence in my abilities is currently low.
Resident Import Elitist
1991 Skyline GTR
(OO\ SKYLINE /OO)
1991 Skyline GTR
(OO\ SKYLINE /OO)
Take a look at the far left cylinder in the pic of the piston bores..are those pistons only relieved on one side of the connecting rod?
They might be on upside down...
I took the silver marks on the pistons to be valve relief cuts, but now that I look at them they might be into solid piston. I think the reliefs are on the other 1/2 of the piston...
Crank up the brightness on your monitor. I'm pretty sure that's what happened.
He mentions installing a zz4 cam. I'll bet he was upping the compression with those pistons and installed them backwards.
It's almost painful to look at those pics and read something he posted:
"..the car runs and starts well up to just past 3000rpm where the engine just falls flat on its face, it seesm like there is something holding it back."
http://www.fiero.com/forum/Forum2/HTML/070540-2.html
When the oil pressure got high enough the lifters wouldn't bleed fast enough..boom!
