Quick Laptop Question
I use an external mouse on my laptop. Is there any way to have the touchpad automatically turn itself off when an external mouse is plugged in? I hate touchpads and I especially hate when I accidentally brush over it in the middle of a CounterStrike firefight. I thought about going into the device manager and disabling it but I didn't know if there was maybe some hidden setting somewhere that makes it disable by itself.
Thanks,
Steve
Thanks,
Steve
87 GT - Automatic. 2.25" Catback.
04 VW GTI 1.8T - APR 93. Weitec 60/40 Cup Kit. GHL Intake. Neuspeed 28mm RSB. Peloquin's Differential.
I don't think there is a way to automatically have it disable, though as you said you can disable it yourself.
Edit. Looks like I'm wrong, there is a way!
Start >> Control Panel >> Mouse
Then at the bottom, you'll see a checkbox that says "Disable Touch Pad when USB pointing device is present"
In case you didn't figure it out, you check that box, and click "OK"
Re: Quick Laptop Question
Probably not what you are looking for, but you didnt say what OSderangedsheep wrote:I use an external mouse on my laptop. Is there any way to have the touchpad automatically turn itself off when an external mouse is plugged in? I hate touchpads and I especially hate when I accidentally brush over it in the middle of a CounterStrike firefight. I thought about going into the device manager and disabling it but I didn't know if there was maybe some hidden setting somewhere that makes it disable by itself.
On my linux laptop I did this to play UT and Wolfenstein ET:
Create file: /etc/hotplug/usb/usbmouse.usermap:
Code: Select all
# el cheapo optical usb scroll mouse: Find your usb id from cat /proc/usb/devices
usbmouse 0x03 0x09da 0x0006 0 0 0 0 0 0 0 0 0
Code: Select all
#!/bin/sh
if test "$ACTION" = "add" ; then
synclient TouchpadOff 1
if test -n "$REMOVER" ; then
# usb.agent sets this variable to point to an executable that
# will be run on remove, if it exists
ln -s "$0" "$REMOVER"
fi
elif test "$ACTION" = "remove" ; then
synclient TouchpadOff 0
fi
You can install syndaemon and set it to disable the touchpad while typing (I set the delay to about 2 secs)
