Rhythmic clunking
Rhythmic clunking
The rear of the Formula just started making a repeating muffled clunking noise that is dependent on vehicle speed. It makes the noise under mild acceleration and all engine braking conditions, but the noise disappears with even mild brake application. I'm going to guess that it's a wheel bearing until I have a chance to investigate further (tomorrow evening). Anyone else care to take a stab at it?
The real problem is that my girl likes to do it in time with the clunking, but I have to go like 100 mph in order to be fast enough for her.
Interesting. How prone are the '88's to this happening? I didn't torque the bolts, but I tightened them pretty well when I put the brakes back together after the clutch job. I can check that before I move the car anywhere else, too.Series8217 wrote:Caliper bolt loose.
Otherwise you have a warped rotor and/or worn slider pins so the brake pad is sliding back when it catches on the rotor every rotation and making a banging sound.
Do you use new locktite when you work on your calipers? I find myself using anti-seize on things on which GM used loctite.
Happens all the time.The Dark Side of Will wrote:Interesting. How prone are the '88's to this happening? I didn't torque the bolts, but I tightened them pretty well when I put the brakes back together after the clutch job. I can check that before I move the car anywhere else, too.Series8217 wrote:Caliper bolt loose.
Anti-seize? Eek. I use loctite. You definitely don't want to use anti-sieze on those bolts. There is very little thread engagement. Use blue loctite. You'll have to get all that antisieze off.. liberal application of brake cleaner should work.Do you use new locktite when you work on your calipers? I find myself using anti-seize on things on which GM used loctite.
If you're worried about thread corrosion preventing future disassembly.. loctite prevent's corrosion too.
:withstupid: Happens all the time! I use blue loctite when I put my brakes back together. It sucks when the caliper comes off, trust me. :puke:Series8217 wrote: Anti-seize? Eek. I use loctite. You definitely don't want to use anti-sieze on those bolts. There is very little thread engagement. Use blue loctite. You'll have to get all that antisieze off.. liberal application of brake cleaner should work.
Do you tighten by hand or torque the bolts? The spec is 28 ftlbs and that's not much at all for a 12mm bolt, considering that lug studs go to 100 ftlbs.Series8217 wrote:Anti-seize? Eek. I use loctite. You definitely don't want to use anti-sieze on those bolts. There is very little thread engagement. Use blue loctite. You'll have to get all that antisieze off.. liberal application of brake cleaner should work.Do you use new locktite when you work on your calipers? I find myself using anti-seize on things on which GM used loctite.
I know you found the problem...
But I had the same thing happen to me.
Drove it like that for 2 weeks before I realized that the problem was the passenger-side seatbelt was hanging outside the car and whanging on the body panels...
Point being: Everyone is allowed a quota of stupidity. How much depends on what your yearly salary is. I.E., the more you make, the less you are permitted to fuck up.
I don't make SFA, so I'm allowed to be as stoopid as I like.
