Back to the dyno
Posted: Sun Nov 19, 2006 11:37 am
After about 80 miles on my new clutch I wanted to get back to the dyno to see the new numbers I am putting down with this setup.
Mods are gasket matched heads, larger cam, poorly done gasket match intakes, DM ported upper to 56mm, Stock 52mm throttle body, Fiero Store Sprint Manifolds, open dump after Y pipe. So really not all that much.
The reason why I have the 52 mm tb on there is because the 56 was sticking at part throttle and was a pain in the ass at slow speeds. So maybe there is a bit more left.
Its def stronger then my old engine. You can see it fall on its face after 4500 rpm and I am hoping that maybe the dual tb intake can correct that. I would like to see what it can do as its obvious the motor dies hard. Not sure when or if I ever get around to dynoing the dual tb though but if I do I will be sure to post the results.
This is a comparo of the old engine with the dual tb vs the new.
This was just 3 runs on the dyno with no tuning. I didnt' play with my safc settings at all.
![Image](http://www.shaun.saturnet.net/pics/Dyno/dynocomparo%20.JPG)
