Lumina 3.4 - what trans
Tha Driver
Post by Tha Driver »
:salute:
sayonara
It's a 4T60E and unless it has zero miles on the drivetrain its not worth anything close to $2500.
Tha Driver
:salute:
sayonara
Used complete motor $800 - $1200 depending on mileage (if its over 50,000 its not worth more than $800 IMO).
Keep in mind crate motors pop up on ebay a lot for $900-$1200. Then one just needs a $100 pick-a-part motor for the manifolds and missing accessories and they have a complete engine with zero miles on the mechanical bits.
Not sure what the 4T60Es are going for...
Tha Driver
:salute:
sayonara
Tha Driver wrote:What about the wiring & electronics?
I was including that
Tha Driver
:salute:
sayonara
Tha Driver wrote:OK thanks again.
Did you roll the car in your avatar? Not a good way to stop a Fiero....
No, just flew it over things and did cartwheels.
Tha Driver
:salute:
sayonara
Mach10
Post by Mach10 »
Is the 283 fuel injected? Because you won't see a whole lot of use out of an electronically controlled transmission without an accompanying ecm. :salute:
Mach10 wrote:Is the 283 fuel injected? Because you won't see a whole lot of use out of an electronically controlled transmission without an accompanying ecm. :salute:
He said paddle shifters. That means whipped's transmission controller.
