Electric intercoolers
http://www.killerchiller.com/
Heat Molecules! Phlogiston!
Weponhead
Post by Weponhead »
is that essentially a bigass peltier *sp?*
Forever-Fiero
Post by Forever-Fiero »
Looks heavy. But -22* will get the god done!! Wont that have a negative pull on the electrical system?
whipped
Post by whipped »
30 amps... it's like an extra fan
is 400 watts enough though?
They should run the exhaust through one in the rear to power the intercooler one in front.
Yes, it's a great big peltier.
Did anyone read the theory of operation? That was a hoot.
Tell them to make one out of inconel to pull power from the exhaust.
Indy
Post by Indy »
lol....60* lower liquid temps means 60* lower intake temps! Yes!
Heat molecules though? Wow. Just, wow.
p8ntman442
cant get enough of this site!
Post by p8ntman442 »
dude you get the power from removing the heat molecules. HEAT MOLECULES, FTMFW!
TrotFox
Post by TrotFox »
The Dark Side of Will wrote:Yes, it's a great big peltier.
Yeah, gotta love pseudo-science babble. Whatever sells the product, I guess?
How do you mean Inconel to pull power from the exhaust? To my understanding Inconel is simply a high temp alloy?
Red 5spd Formula
Trot, the NA, fox... : (
Looks like the charge air goes through aluminum heat exchangers in the intercooler version. I don't think that would last well if it passed exhaust gas. Inconel is also very corrosion resistant.
whipped
Post by whipped »
bah... stainless
TrotFox
Post by TrotFox »
The Dark Side of Will wrote:Looks like the charge air goes through aluminum heat exchangers in the intercooler version. I don't think that would last well if it passed exhaust gas. Inconel is also very corrosion resistant.
I suppose my question should have been, "how do you propose to create power with an Inconel exhaust?" Then I made the connection and did a bit of reading. I wasn't previously aware of the Seebeck effect although I really should have been.
Trot, the gray, fox...
Blue Shift
Post by Blue Shift »
Haha, using exhaust heat to make power, to run a big peltier to cool the intake charge air? That'd be cool...
400/800W though? I have some serious, serious doubts as to how effective that'd be? My 1500W room heater struggles to warm air 30 degrees at much, much less flow than a motor is going to consume. Especially a high output turbo motor. The extra alternator draw isn't going to be pretty, either. I don't have a degree in thermodynamics, but that's my educated guess.
