Difference between 85-87 and 88 harmonic balancer?
coinage
Post by coinage »
what are the differences other than the 88 is neutrally balanced? is there a way to tell the difference without taking them to my machine shop?
I got 2 with my falconer set and i am assuming they are performance ones i am hope to use one of those insted of dropping $300 on a new one...
Thanks
Mach10
Post by Mach10 »
Harmonic balancer should always be neutrally balanced, since it's job is to absorbe harmonic vibrations; not create new ones.
GM motors were balanced on the flywheel.
Other than that, I have no idea... Different belt pulley p'raps (didn't 88s get a serpentine rather than V belts?)?
pretty sure they are interchangeable.
Xanth
Post by Xanth »
My 88 still has v belts.
BigRedDeckSpoiler
Post by BigRedDeckSpoiler »
I've always understood that all the 2p8 V6 harmonic balancers were the same.
The pulley bolts to the balancer. Whatever kind of belts you use.
My 88 has a V belt for the A/C and a flat belt for the WP and alternator.
BRDS
Pyrthian
Post by Pyrthian »
yes, I think they are the same
but, not sure about the timing marks
