lug nut locks
lug nut locks
what can i use to remove the lug nut locks with out the key socket?? i was gonna torch-em but that would be a bad day for my rims :scratch:
Get another locking lug nut key (I think there were like 18 of them that GM used on the Fiero) and POUND it onto the nut you can't get loose. Helps if you can get another key that's similar to the one you have.
Or go to the GM dealer and borrow his collection of keys and sit in the parking lot trying each one until you find the one that matches.
If the lug nut is stripping, frozen or otherwise impossible to get off, you can drill out the stud. I had to do this before. It's time consuming but certainly saves your rim.
I just hammered on the tightest standard 6pt socket I could find from my impact set. Didn't hurt the socket (although it was fun removing the lug afterwards) at all.
Just don't expect to be able to use an impact gun, since it'll be more likely to round it off than loosen if the nut's at all frozen. I just used a breaker-bar and some muscle. :salute:
I took mine to a local shop, they have sockets with teeth on them for removing stripped lug nuts, it should take them about five minutes. Oh and as far as the gator grip goes, don't waste your money, I bought two of those, one was like a centimeter too small, and the other was too big to fit on the lug nut, because it couldn't clear the wheel.
1998 Mustang GT
![Image](http://i81.photobucket.com/albums/j225/product1620/FORDEMBLEM.jpg)
