water temp sensor L67
Posted: Thu Jun 07, 2007 9:27 pm
by dgzfiero
Does anyone know where the water temp sensor is on a L67? 2000 SSEi motor if there is a difference. I've looked all over the top of the motor that I can see. It is showing P00118 coolant temp circuit high input on a code reader.
Posted: Thu Jun 07, 2007 9:47 pm
Should be near the thermostat.
Maybe in a cylinder head.
Posted: Fri Jun 08, 2007 12:21 am
by Jinxmutt
Its under the T-stat. It threads in 'upwards'. It comes really close to the crossover and usually has a silver heatshiled tube over it (from the factory).
Look near the 'arm' of the engine stand.
Posted: Fri Jun 08, 2007 6:06 pm
by dgzfiero
OK I never looked under it there. Thanks
