Would you put these gauges in your Fiero?
I can't decide if I want to use them or sell them. Right now I have the stock 120 speedo with a Sunbird turbo tach. It almost looks stock. On the pillar I have an Auto Meter Phantom boost and narrow band AFR gauge.
Then I have these Auto Meter Ultra-Lite gauges.
I would get the Ultra-Lite Wideband and replace the Vacuum gauge with a boost gauge.
The center pod sticks up rather high and there is no more "Check Engine" light.
I don't think the speedo and tach are bad. My issue with that setup would be that it doesn't have the full functionality of the stock dash (IE, no check engine light and I'm sure it's missing a lot of other stuff).
I wouldn't put 6 gauges on the center stack. I'd drop down a size and put three or four across, but I wouldn't go with two rows and I wouldn't want six. A vacuum gauge is of course a bit limited on a turbo engine.
The Sunbird tach, however, is EASY.
I'd put oil temp in the main gauge pod and keep the boost gauge on the a-pillar.
Screw the tach, install the entire cluster. I have been running this for 2.5 years now, with no problems. Little wiring changes are needed, just extend the wires about 3", and eliminate all repetitive wires. Only problem is the speedo is for an ECM generated 4000PPM 1 wire output.The Dark Side of Will wrote:I don't think the speedo and tach are bad. My issue with that setup would be that it doesn't have the full functionality of the stock dash (IE, no check engine light and I'm sure it's missing a lot of other stuff).
Next time I take my cover off, I should mark down the wiring for it, I had it but lost it. Then you can put 2 gauges in the stock center pod GT gauges, since all the normal gauges are in front of you, tach, boost, speed, odometer, temp, oil pressure, voltage, and fuel, for idiot lights it has check gauges, Service engine soon, seat belts, turn signals, brake, high beams, deck ajar, and the shift up arrow.
Only 16 wires feen the entire dash through 1 plug.
I would say not to use that huge ass center guage pod. Maybe rework the main cluster and relocate the odometer to the lower left, add some LEDs for check engine, etc and put the fuel guage (or other) between the tach and speedo if it fits. Then after you get rid of the Vacuum, you only have 4 guages to mess with in the center. If anything, I would place the extra guages where the center vents are rather than have that huge stack. Also, befarrer's set-up looks pretty good too.
Fiero Build Thread here:
