Two Fiero GT's for sale/trade (lots of pics)
Posted: Sat Aug 18, 2007 8:56 pm
I 'may' be working out a trade for the silver one to get an '88 T-top car, but nothing's been decided yet.
I want to trade or sell in whole or in part one or both for any and/or all of the following:
-An AWD wagon or small SUV with less than 100k miles in good shape, 95ish or newer (need to get little sister a roomy winter-able car)
-An '88+ full size Chevy/GMC truck w/ a V8 and reasonably low mileage in decent condition, other options fairly open
-An '88 Fiero GT in decent shape
-$3200obo for both
Here's details:
First, let me say that some of the pics make details of the cars look a little better than they are, but nothing very dramatic.
The '87 (silver):
-236k miles
-35k on the reman'd 2.8 from GM (I bought it like that, but have the reciept).
-Power windows/locks/mirrors
-Sunroof
Everything internally to the engine is great, no funny noises from in there, no smoke, etc.
It was a southern Cali car, so hasn't had salty winters
The good:
-All exterior lights work
-All gauges work... well as well as stock Fiero gauges do.
-Interior is in pretty good shape overall, includes nice seats from a '96 Firebird w/Fiero tracks (stock height)
-Speedhut reverse indiglo gauge faces (blue or green switchable backlight)
-New Walbro 255lph fuel pump
-New KYB front shocks
-New right rear outer tie rod
-New polyurethane cradle and sway bar bushings
-Aiwa CD player, aftermarket speakers/small sub in factory box (not sure which), sounds pretty good
-Perfect windshield, no chips
-Tires are in good shape
-Car has almost no rust
-A/C works
-Clean and clear title
-It's all there
The bad:
-Idle surges most of the time, occasionally it'll settle on a perfect idle. Lately it's been not wanting to stay running when cold, but won't stall once it gets a little heat in there.
-Will occasionally buck and kick while cruising on the highway for a bit of time, then goes away and cruises smooth. I did a normal tune up (plugs, wires, cap&rotor, fuel filter, air filter) but none cured these. It throws 4 engine codes (EGR, TPS, and two others I forget), but the TPS measures right. The EGR probably is bad, but shouldn't cause that. I believe the two other codes were related to those two.
-The tranny will grind into second if not shifted slowly, but goes fine if so. Reverse will also grind unless it's put into a forward gear first (somewhat normal).
-The brakes have a small leak somewhere, have to add a little fluid every 1-2k miles or so maybe.
The not as bad:
-Minor oil leak, none really needed to be added between changes, though.
-Needs a shift select cable, it's somewhat hard to move from side to side (though I'm used to it).
-Rear bumper has small crack from winning a fight with the mailbox (poor mailbox).
-Paint (obvious in pics)
-Horn doesn't work
-Parking brake is weak (hence the downhill fight with the mailbox- I leave it in gear now )
-Slight wheel vibration at 75ish mph
-Rear trunk carpet really dirty
The '86 (black):
-230k miles
-I was told 15k on the ARI 3.4 stroker and Getrag 5-speed rebuild, which is believable.
-Comp Cams 260H cam
-Ported heads (I don't know how much, but was told they were ported by a local shop in VA)
-Roller rockers (was told this, didn't verify)
-Sprint headers
-3" catback
-MSD 6 ignition
-Autometer tachometer (condition reflects interior, but it works well)
-Eibach lowering springs
-Poly bushings all around, including cradle and sway bar
-Short throw shifter (not sure which, but is an aftermarket one)
-Quarter window scoops
I bought this car as it sits a few months ago. It runs, but really needs TLC. It sounds very mean, and would be a quick car with work and a proper tune.
The good:
-Above listed
-Tight steering
-Handles like it's on rails even with old tires
-Parking brake works well
The bad:
-Title issue, 3rd digit typo'd as a "Z" on the title when it should be a "2" (Pontiac Division). No 3rd digit "Z" even exists. I ignorantly missed the issue when it had a VA title, and sent it through to get an MD title in my name. Now both states say "deal with the other state". I'm sure there's a way around the mess but I don't have much time to haggle with the states. It is an otherwise clean title in my name, and is legit, just erred.
-Clutch slips, I'm pretty sure it's from the rear main leaking onto it judging by how it acts. It'll only slip under hard acceleration, but not every time. Wants to grab nicely occasionally, and under normal accel and cruise.
-Cooling fan quit coming on right after I bought it (go figure). I haven't looked to see why.
The not as bad:
-Engine doesn't run perfect, probably only needs a good tune. Mostly idles great
-Minor other oil leaks
-Door lock 'covers' are missing, have to slide back black trim to get key in doors (hard to explain)
-Interior isn't great, see pictures.
-Temp guage reads erratically
-Oil pressure gauge doesn't work
-Headlight motor won't stop running on or off so they were put up then unplugged (this is how it was told to me, I haven't even messed with them) though both headlights do light up.
-Horn doesn't work
-Paint (flat black over red, not done great)
-Needs new tires all around
-Wheels have dirty stains that won't come out (hard to see in pics)
-Missing rear trunk carpet
-Chip in windshield
-3" exhaust underneath car somewhat crushed, but still open enough to get exhaust out.
-A/C doesn't work
Taking the parts from the '86 and putting them in the '87 with some attention to detail and a tune would make for an awesome all around Fiero. There isn't a lot one needs that the other doesn't have. Otherwise, some troubleshooting and extra parts and work would make for two decent drivable Fieros.
I was going to swap in the whole front cradle and the whole rear cradle after re-sealing the engine and putting a new clutch in, then do a '730 ECU swap and tune, finishing it off with a (proper) paintjob. Unfortunately, I just have too much on my plate right now and I need a truck or any of the above, so lets make a deal!
-$3200obo for both
Here's details:
The '87 (silver):
-236k miles
-Sunroof
The good:
-A/C works
-It's all there
The bad:
The not as bad:
-Horn doesn't work
The '86 (black):
-230k miles
-Comp Cams 260H cam
-Sprint headers
-3" catback
-MSD 6 ignition
The good:
-Above listed
-Tight steering
The bad:
The not as bad:
-Horn doesn't work
-Chip in windshield
-A/C doesn't work
