Has anyone put one of these on?Is it pretty much cut of your old converter and U-clamp the head pipe on? Or should I just forget it?, Because its a pain in the butt.
yup - pretty much it.
unbolt the cat from the downpipe/y-pipe, and depending on how the cat is attached - remove it - and replace with the new piece. it will rust tho - so, good idea to do what you can to protect it.
