Update on me!!!!
Moderator: ericjon262
Update on me!!!!
well blew up my 4wheeler with about 20 hours saturday, but a new kfx450r that night. went shooting today. umm i wish everybody here could own one of these...
http://pictures.sprintpcs.com/share.do? ... =RETRIEVED
my fiero is faster then yours. the end. except you fieroX
So are you going to buy the stuff you said you would? Including the fuel sender that I pulled out of the tank, then OHM'ed, then plugged into my car, all to make sure the most reliable part ever on a car is still working?
Re: Update on me!!!!
well i had a nice long typed out reply last night, but when i posted it the board returned with not available. so hmm. it's coming. the turbine housing is getting ceramic coated black. the sheet metal upper intake had the base plate lasered last week so it matches every contour on the lim and it's out of 1/2" aluminum. gonna get started on welding all the top pieces together next week. my headers are done, coated, and wrapped. the heads have had extensive port work. along with the lim port matched to the heads and the aluminum gaskets cleaned up a little to. all that's really left is a y pipe, down pipe, intercooler pipe routing, and some tuning. i will be personally upset if the car doesn't turn a high 9. since i refuse to cage my car i'll only be running 1/8 with it until i can get it to run low 6's@115+. then i'll open it up to get thrown off the track. :sex: but that's about it. i've got 10000 things going on at once and i don't know which from what. there's a total of 3 torn apart engines at my house. two cars, and a 4 wheeler. the quad has the craziest designed engine i've ever seen or worked on. i'll post pics later when i get time.
