Later in life, when I've gotten other aspirations out of the way and can afford to waste money on highly unlikely apocalypse gun. I live in the city. A compact carry for mobile, shotty for home. No body armor to penetrate.Indy wrote:.308 AR SBR...It wants you to own it.
Thanks for the idea though, I figured it existed, just hadn't looked.
1. That of course is an opinion. Every army on planet earth is fielding switching to a larger caliber round. FMJ 5.56's aren't cutting it. Some say the EM-2 .280/7mm NATO was the perfect round, being a compromise between the two.Aaron wrote:1.The .223/5.56 is one of the greatest rounds created.
2. ...I will guarantee you will shoot tighter, faster groups with a 9mm Glock than a 10mm Glock.
3. The Hornady TAP ammo
2. Volume or precision. One 7.62 round is all it takes. You'll probably need more than one with the smaller if you aren't a marksman.
3. Expensive and hard to find. When the zombie apocalypse comes, you're going to run out of your $2 per round ammo quickly. Then you're only going to be able to find military and target grade ammo which is undersized and ineffective at stopping large angry targets in a firefight.
