VVT N* - 700/1300 BIN
http://cgi.ebay.com/ebaymotors/4-6L-Nor ... dZViewItem
This is like 1/3 the price of the lowest one I've ever seen.
:thumbleft:
:thumbleft:
My fiero is aliiiive!!
Reading this Quad 4 article: http://www.quad4forums.com/forums/showthread.php?t=4440
I am reminded that the Q4 waterpump has a sprocket in the Q4 timing chain. The longitudinal N*'s could be set up to drive the waterpump off the intermediate timing sprocket. This would not only be cool, like an Indy car accessory drive, but would reduce serpentine complexity and increase accessory drive durability and reliability.
You *might* be able to write your own code for it with something like the Megasquirt... From what I understand they're using a fairly fast processor. Might be enough to control a few phasers.The Dark Side of Will wrote:Sweeet. That's down to half the cost of the engine management needed to run it.
As much as I hate the simplicity of megasquirt, I think this would be a valid application for it... since nothing else works, or would be too much work.
will, i just spent about 20 minutes on uspto.gov and couldnt find the pattent for the cam phasors. If you can dig up the pattent numbers somewhere that would be awesome. Ask the seller to get the number off the phasors :thumbleft: maybee????
anyways, I heard that the gm design is now out because the patent on the design ran out, and they took it for free. take that with a grain of salt htough i got it from a honda guy.
