Page 6 of 12
Re: My NEW turbo setup
Posted: Tue May 13, 2014 1:52 pm
maybe taper is the wrong word. Bevel might be better. There is a bevel on the butterfly where it seals against the side of the runner. The guy at the machine place measured it but I forget the degree he stated. it might be on a notecard but ill have to double check.
Posted: Tue May 13, 2014 4:32 pm
as long as it's for the right size bore, I can't see the taper being that big of a deal. I do know a higher angle on the leading edge will make for a touchier/ snappier throttle then a shallower angle.
Posted: Wed May 14, 2014 2:11 am
Shaun41178(2) wrote:maybe taper is the wrong word. Bevel might be better. There is a bevel on the butterfly where it seals against the side of the runner. The guy at the machine place measured it but I forget the degree he stated. it might be on a notecard but ill have to double check.
It's not a taper. It's a bevel, and the bevel is the opposite direction on opposite edges of the plate. That's so it can sit at a slight angle in a parallel bore and not get jammed closed.
Posted: Wed May 14, 2014 3:27 am
Exactly, where I took it they said the couldn't duplicate it with their machines
Posted: Wed May 14, 2014 6:33 am
It requires making a fixture that's something of a PITA to make.
Maybe Steven could 3D Print one...
Posted: Sat Jul 26, 2014 7:04 pm
Bump for updates?
Posted: Thu Sep 25, 2014 11:48 am
Another bump for updates...
Where's the 500 RWHP dyno sheet?
Posted: Mon Sep 29, 2014 5:41 pm
no updates.
Posted: Tue Sep 30, 2014 9:33 am
by CincinnatiFiero
SHAUN HAS BEEN WORKING ON THIS FOR TWO YEARS AND COUNTING
Posted: Sun Oct 19, 2014 11:55 am
semi recent pic of how I routed the charge piping without the t-bolt clamps. No intercooler in this pic but it will be hooked up with more boost. wastegate is at 3.5 psi right now but changing that out and looking at 80lb/hr injectors too.
- IMG_0041.1.jpg (143.09 KiB) Viewed 9249 times
Posted: Mon Oct 20, 2014 3:14 pm
CincinnatiFiero wrote:SHAUN HAS BEEN WORKING ON THIS FOR TWO YEARS AND COUNTING
I almost died!
Posted: Thu Mar 26, 2015 4:01 pm
http://60degreev6.com/forum/showthread. ... ITB-intake
so I take it we will never see a pass or a dyno on this engine?
Posted: Sat Apr 04, 2015 4:18 pm
Posted: Mon Apr 06, 2015 5:58 am
by Emc209i
No intercooler?
Posted: Tue Apr 07, 2015 9:06 am
I have an intercooler. That pic is 7 months old and was only done as a mock up and photo op
Posted: Tue Apr 07, 2015 1:21 pm
Lol
Posted: Tue Apr 07, 2015 3:06 pm
Shaun41178(2) wrote:I have an intercooler. That pic is 7 months old and was only done as a mock up and photo op
Where's the 500 RWHP dyno chart?
Posted: Wed Apr 08, 2015 11:56 am
must not have seen my latest video. i posted it about 7 months ago.
https://www.youtube.com/watch?v=M8xaHebT4DU
Posted: Wed Apr 08, 2015 1:33 pm
how does an idle video mean the car makes 700 hp? does that mean my car makes 550hp? the only dyno run on that youtube account is an iron head 3.4, hardly 700 hp...
Posted: Thu Apr 09, 2015 4:45 pm
A) I want my 0:28 back (Didn't bother to watch the whole thing)
B) That video contains neither a 500 HP dyno pull, nor opening a can of whoopass on the variety of car which would indicate that said Fiero had 500 RWHP.
