11 1/4" brake upgrade INFO & SPECS
- Location: Chained up & locked in a box. Sinking to the bottom of a lake
Ok, I haven't seen too many threads on here about the lebaron brake upgrade. I'd like to gather some info on it and put it in common place where people can use it for a reference when getting parts together. Jump in and correct me if I'm wrong or to add anything I've missed (and most likely have. ).
Parts needed:
Front calipers: '83 - 94 S10 Blazer (4WD)
-CarQuest P/N 18-4129 left & CarQuest P/N 18-4128 right (unloaded)
-loaded caliper P/N's are 16-4128(9) for right and left
* also read that '85 Seville caliper is same P/N as blazer
Rear calipers: '80 - 85 Cadillac Seville CarQuest P/N 18-4138, rebuilt & CarQuest P/N 18-4139 Rear Caliper, rebuilt
*These calipers must be identified with casting Nos. 020 and 021
Master cylinder: CarQuest P/N 2218 Master Cylinder, (92-94 Chev/GMC Blazer/Jimmy) Aluminum, 1.125" bore
Rotors: Raybestos P/N 7993 11.260" Vented Rotors (rear, 89-94 Chrysler LeBaron) Will front rotors from the same vintage car work as well?
Of course you'll also need to make up a set of caliper adapter brackets & gather all the other odds and ends. The link below has the bill for the rest of the materials.
http://home.earthlink.net/~david.cole/f ... t/walt.htm
Since the inception of this package I think a few other members (Will, Kohburn) have made revisions/improvements to this upgrade so I don't know how accurate the materials list and drawings are after any changes.
Anyway, I'll :stfu: now. :thumbleft:
Parts needed:
Where'd you read this info?
Give credit where it is due.
These are the two threads in which I've posted that info.
http://www.fiero.com/forum/Forum1/HTML/048271.html
phpBB/viewtopic.php?t=285
You're pretty much correct... I just have a small correction to make to the application...
The S10 is a pickup truck. The Blazer based on the same frame is called a "T10".
The issue of front vs rear rotors is discussed on the Pfiffle thread.
I would surmise that they would be more or less the same for "braking power" with stopping distance with either being more a function of the tire compound and width. The 12" system would probably exhibit greater fade resistance. The weight would probaby be a wash as the greater weight of the 12" rotors would be offset by the aluminum calipers.
The 11.25" system is definitely cheaper, as it does not use Corvette parts.
Also, for a bit more money it can be upgraded with Wilwood or SSBC aluminum calipers and definitely have a weight advantage.
Beretta, Grand Am, whatever. Would you feel better if I said Grand Am? I know they're the same fucking car. :knob:
So the caliper is farther out, but is the surface of the piston any larger? Is the caliper itself larger? The rotors themselves have no problem dissipting heat, and they've seemed to do well for me. I'd like the looks of bigger rotors in my wheels, but if there is no complelling reason to want the caliper farther away from my axle it seems like kind of a hair shirt for me.
I want the 12" Wilwoods from HMS :sex:
I've done the 12" as can be seen at the other place. I also have the 11.25 on my 84, but that has an 88 cradle, and so I'm in the process of trying to get the 12" adapters so I can use the vette rotors back there too. The 12" was a bit more work to install, and a bit more money.
For everyday driving, besides the WOW factor, I would probably do the 11.25 again before I did the 12". If you are lookin for the whole 'race' thing, there are better rotors available for the 'vette swap, better pads, and you can use a MC that was designed to be mated to those parts, where as the Blazer still isn't 'right' as far as I'm convinced. I'm actually considering using the vette MC for my 84 rather than the blazer...
You know what it does, it lowers the line pressure from the master cylinder to the caliper, because of the increase in mechanical advantage on the rotor.
Big deal. If you have trouble pushing the pedal down, work out. If you want to decrease stopping distances, put better rubber and brake pads on the car.
stimpy wrote: So the caliper is farther out, but is the surface of the piston any larger? Is the caliper itself larger? The rotors themselves have no problem dissipting heat, and they've seemed to do well for me. I'd like the looks of bigger rotors in my wheels, but if there is no complelling reason to want the caliper farther away from my axle it seems like kind of a hair shirt for me.
