This came off the dohc car. Its an ebay special. I measured it to a 46 trim even though it was sold as a 57.
inducer is 50.62 and exducer is around 70 something mm's
Will make up to 400 hp at 14 psi of boost Here is the compressor map.
This turbo will be good for a stock 2.8 or a mild 3.1 or even a mild 3.4 pushrod iron head looking to make a bit more power. Spool will be quick and the compressor is more efficient then your standard T3 on the same motor. Will be good for 10 lbs or less in my opinion.
Internal wastegate but can easily be converted to external if thats your desire.
Little to no shaft play. No more then factory.
I can post pics if needed. Asking only $100. Not too many miles on it but don't have an exact number. I am selling because I need something bigger.
T3/T4E 46 trim for sale
bolts and oil fittings are pictured but are not
included. not sure how large they were going to come out so I just posted the link instead of inserting them.
http://i263.photobucket.com/albums/ii14 ... 0_1503.jpg
http://i263.photobucket.com/albums/ii14 ... 0_1502.jpg
http://i263.photobucket.com/albums/ii14 ... 0_1501.jpg
