engine wire harness help
well I got a new engine with 46k on it.. so a buddy and I pulled the engine but we are no loger talking long story. I just need to know how the wire harness routed around the engine. any thing will help thank you for your help and time.
Re: engine wire harness help
Year, engine, transmission?
87 2.8 automaticCincinnatiFiero wrote:Year, engine, transmission?
Should be fairly self explanatory. You know the harness comes through the firewall pretty much in the middle of the front of the engine. Find the first connector on the harness and match it to a sensor on the engine and keep following and clipping connectors in. Had to do the same thing with my Northstar harness which wasn't remotely correct for a fiero but figured it out. Good luck.
The smooth flat parts of the harness slip between the intake and valve covers.
