anyone on here ever braze stainless steel, or have any info on strength and durability?
I'm thinking about taking my 3500 fuel rail (stainless) and brazing a fitting to it to make it a return style setup instead of returnless. the end goal is two fold, my current fuel rail is aluminum, which doesn't play well with E85, and I think I can package the stainless rail better than the aluminum rail.
brazing stainless?
brazing stainless?
Re: brazing stainless?
You can probably package it even better by mounting your regulator to the firewall or strut tower and running the return line from there...
I haven't brazed stainless. I bet it needs a specific brazing rod, but then should be the same as brazing anything else.
Having had a bunch of aluminum welding done for The Mule's A/C system, next time I have a build like that, I'll braze all the joints... so much less hassle.
- neophile_17
You could definitely do it with silicon-bronze but as Will pointed out there's an easier way. Pairing the stock rail with the C5 vette fuel-filter/regulator is what I've been planning. I believe some have also used the fuel pressure test port as a return as well. Good luck!
85 SE LZ4 Pending...
