Alright, the brake hose prices for a 68 mustang are absurd, so I was wading through some catalogues and they show braided AN 3 line with a banjo on one side.. So far so good, provided the banjo works (The 68 has a big rectangular one. These are small circular ones. Provided the hole and width are the same, should they both work?). Anyways, so obviously I need to connect these to my regular 3/16 Y flare brake lines.. How does that work? Am I supposed to find some sort of adapter that screws into the 3an fitting and converts it to a normal Y-flare adapter, or...? Thanks
I'm aware this isn't fiero related persay, but brake line is brake line.
Brake lines (AN). Stupid question for some
http://www.holley.com/index.asp?division=Earls
Yes, the small round banjos will work.
Earl's will have all the raw parts you need. You can put them together any way you need to.
